2 Pages12>
Offline soletto
#1 Posted : 19 October 2018 22:03:14(UTC)
soletto
Austria
Hey,
hope the function to export a matrix into an excel with activated makro will work.
Test.sm (9kb) downloaded 28 time(s). Wallthickness.xlsm (97kb) downloaded 27 time(s).
It cannot save the file :-(
lg
Stefan
#2 Posted : 20 October 2018 12:21:29(UTC)
Seems a problem of the ClosedXML library when saving in the existing file... I'll check if can be solved in some way...
Edited by user 20 October 2018 12:26:55(UTC)  | Reason: Not specified
Offline soletto
#3 Posted : 20 October 2018 13:52:27(UTC)
soletto
Austria
That would be great!!!!!!!!!!!!
Thats at the moment my only problem since i always need a lot of makros in my excel file
Stefan from www.BHDT.at :-)
Offline G-Tate
#4 Posted : 22 October 2018 14:41:20(UTC)
G-Tate
Rank: Member
I still don´t get the way how to import xlsx files into SMath files.
It seems, that the xlsx file is found, but there is an error, which sais
my SMath file doesn´t exist.
Would be happy about your help.
Thanks.
G-Tate
Offline Razonar
#5 Posted : 22 October 2018 18:31:54(UTC)
Razonar
Uruguay
Was thanked: 822 time(s) in 520 post(s)
Hi Tate. The word unavaible "Page1" worksheet isn't about a SMath file, it's about a "Page1" worksheet in the "Excel workbook" named "SMath_Test" (without extension), which I guess that don't exist too (because the name of the Excel file requires the extension, not only the name).
You can see examples about how to use the plugin here:
https://en.smath.info/fo...mport-Export-plugin.aspx
or directly here:
https://en.smath.info/fo...urce.ashx?a=1772&b=2
Offline soletto
#6 Posted : 22 October 2018 19:44:28(UTC)
soletto
Austria
Try to add the ending to the filname .xlsx and check if Page1 exists
Seems to be that Page1 is not there in the file
#7 Posted : 22 October 2018 20:11:27(UTC)
If you don't give an extension xlsx is assumed as default; as pointed out by Alvaro and Stefan you have to check if the the worksheet exists in the file
excel workbook = the whole file
excel worksheet = each single tab in the file
Offline tomtit
#8 Posted : 24 October 2018 16:26:51(UTC)
tomtit
Hello Davide,
The plugin doesn't work with the latest Smath beta.
It crashes right away during plugin installation:
I tried it in office on Win10 and at home on Win 7,
all the same. I'm using 32-bit SS on 64-bit Windows.
thanks 1 user thanked tomtit for this useful post.
on 24/10/2018(UTC)
#9 Posted : 24 October 2018 18:54:08(UTC)
Thank you, confirmed.
Latest release deleted.
Edited by user 24 October 2018 19:33:48(UTC)  | Reason: Not specified
Offline G-Tate
#10 Posted : 25 October 2018 16:17:09(UTC)
G-Tate
Rank: Member
Thank you very much guys!
I didnt get, that the second name needs to be the sheet name from the excel workbook.
I just tried it with the smath file name.
I should´ve think about it, that the import anyway goes to the actual smath file.
Dry Biggrin
G-Tate
Offline soletto
#11 Posted : 25 October 2018 19:22:29(UTC)
soletto
Austria
Could you solve the issue with the import/export of xlsm. Excel Files with Makro?
Best regards,
Stefan
#12 Posted : 25 October 2018 19:41:10(UTC)
Might requires some time. I have to dig the GIT repo for the latest version of CLosedXML that supports .NET 3.5, inspect the code (not mine) and troubleshoot the bug (if possible).
Offline soletto
#13 Posted : 25 October 2018 19:48:46(UTC)
soletto
Austria
A ok i understand. I hope that would be possble in some time.
#14 Posted : 25 October 2018 19:48:58(UTC)
#15 Posted : 25 October 2018 21:49:05(UTC)
After a survey with the debugger, I found that the issue is known without clear solutions.
The error message is:
Exploring the xlsx archive I found a file named "vmlDrawing1" that contains the br tag (a newline tag in html format, should be a self-closing tag to make it compatible with the xml parsers);
That is a button with this text:
Code:
Werkstoffdatenbank
öffnen
If you remove the neline character it should save correctly.
Edited by user 25 October 2018 21:58:09(UTC)  | Reason: Not specified
Offline soletto
#16 Posted : 25 October 2018 22:05:12(UTC)
soletto
Austria
what you mean with removing the character?
#17 Posted : 25 October 2018 22:06:38(UTC)
Edit the button text, replace newline with a space (go before the first character of the second word, backspace, then space)
Edited by user 25 October 2018 22:11:14(UTC)  | Reason: Not specified
Offline soletto
#18 Posted : 26 October 2018 11:18:48(UTC)
soletto
Austria
No working :-(
Now i cant import the loadcases row.
Exporting into xlsm seems not working :-(
Test.sm (7kb) downloaded 13 time(s). Wallthickness.xlsm (92kb) downloaded 14 time(s).
lg
Stefan
Edited by user 26 October 2018 11:22:44(UTC)  | Reason: Not specified
#19 Posted : 26 October 2018 15:25:06(UTC)
If I use your first SMath Studio worksheet with the latest workbook it seems to work for me.
In your latest worksheet
- first import function name ends with "M" instead of "X" in the subscript that is a function not defined
- in second import the column A of the excel worksheet returns several circular reference exceptions (there aren't stored values even opening it with excel and the plugin isn't able to calculate one... I might return 0 or the cell formula...)
Edited by user 26 October 2018 16:29:22(UTC)  | Reason: Not specified
Offline soletto
#20 Posted : 27 October 2018 09:29:22(UTC)
soletto
Austria
dont understand what you mean. I tried but nothing is working :-(
Does the Makro have an influence on the procedure?
Guest (2)
2 Pages12>
