SMath Studio Forum
Bugs & Problems
[XlsxImportExport] Exporting Matrix into xlsm File
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,653 Location: Italy Was thanked: 1340 time(s) in 879 post(s)
Originally Posted by: soletto dont understand what you mean. Originally Posted by: Davide Carpi If I use your first SMath Studio worksheet with the latest workbook it seems to work for me. smath worksheet from post #1: Test_#1.sm (9kb) downloaded 8 time(s).excel workbook from post #18: Wallthickness.xlsm (94kb) downloaded 9 time(s).This works for me. Originally Posted by: Davide Carpi In your latest worksheet - first import function name ends with "M" instead of "X" in the subscript that is a function not defined In post #18 you changed the content of the SMath worksheet. This is the typo I was talking. As you correctly wrote in first post, it should be: Originally Posted by: Davide Carpi - in second import the column A of the excel worksheet returns several circular reference exceptions (there aren't stored values even opening it with excel and the plugin isn't able to calculate one... I might return 0 or the cell formula...) This is the new range you are trying to import in the SMath worksheet #18. The range rewritten top-left:bottom-right is A5:G150. The plugin fails loading the first column (I see a circular reference exception in the debugger, thrown by the ClosedXML library), that is something I'll look into. Edited by user 28 October 2018 11:55:41(UTC)
SMath Studio Forum
Bugs & Problems
