SMath Studio Forum
Samples
Animation double pendulum and a pendulum on a spring
Joined: 15/07/2010(UTC) Posts: 437 Location: Beer-Sheva Was thanked: 520 time(s) in 288 post(s)
1 user thanked Ber7 for this useful post.
3 users thanked Ber7 for this useful post.
on 29/05/2013(UTC), on 29/05/2013(UTC), on 29/05/2013(UTC)
2 users thanked Ber7 for this useful post.
on 06/06/2013(UTC), on 06/06/2013(UTC)
Rigid rod rocks on a circular surface (Ali H.Nayfeh,Dean T.Mook,Nonlinear Oscillations,1995)Used an ODE plugin. Edited by user 31 July 2013 01:58:28(UTC)
| Reason: Not specified
on 30/07/2013(UTC), on 31/07/2013(UTC)
I 'd propose some adjustments to the functions x(t) and y(t) x(t):eval(r*(sin(θ(t))-θ(t)*cos(θ(t))))y(t):eval(r*(cos(θ(t))+θ(t)*sin(θ(t))))The differential equation does not account for h, therefore it is correct only for h=0 (rigid bar with no thickness). Edited by user 31 July 2013 00:32:20(UTC)
2 users thanked mkraska for this useful post.
on 31/07/2013(UTC), on 31/07/2013(UTC)
Thank you,Martin! Your comments are absolutely correct. I really made a mistake, you have corrected. Workheet updated. Thank you again. Fridel Selitsky.
I should add that the equations of motion of the center of the rod obtained by Martin, are the parametric equations of the involute, which corresponds to the physical meaning of the problem.
Fluctuations of three loads (Ali H.Nayfeh,Dean T.Mook,Nonlinear Oscillations,1995)The system consists of two extreme loads mass m1 and medium load mass m2 (2m1> m2). If the average load deviate from the equilibrium position, the system begins to oscillate
on 11/08/2013(UTC), on 11/08/2013(UTC), on 11/08/2013(UTC)
Pendulum Dangling from a Slider-Crank
on 27/08/2013(UTC), on 29/08/2013(UTC)
SMath Studio Forum
Samples
