23 Pages«<1617181920>»
Offline uni
#341 Posted : 14 September 2018 00:14:23(UTC)
uni
I'm not shure about BodePlot and TransferFunction. I think Maple V Release 5 does not support these functions.
You must use something like this:
Edited by user 14 September 2018 00:25:11(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
Offline Andrea993
#342 Posted : 14 September 2018 10:18:33(UTC)
Andrea993
Rank: Member
OK but in Bode the graph should has logarithmic scale (and it misses the phase plot (not a problem)). Is there some graphs plugin that does logarithmic scale, without I have to simulate it?
Edited by user 14 September 2018 10:20:11(UTC)  | Reason: Not specified
Offline uni
#343 Posted : 14 September 2018 11:37:40(UTC)
uni
ZedGraph can do that.
Edited by user 14 September 2018 11:45:24(UTC)  | Reason: Not specified
Russia ☭ forever
on 14/09/2018(UTC),  on 14/09/2018(UTC)
Offline mkraska
#344 Posted : 14 September 2018 11:45:05(UTC)
mkraska
Was thanked: 1127 time(s) in 723 post(s)
ilt.sm (19kb) downloaded 42 time(s).
thanks 3 users thanked mkraska for this useful post.
on 14/09/2018(UTC),  on 14/09/2018(UTC),  on 14/09/2018(UTC)
#345 Posted : 14 September 2018 18:59:19(UTC)
Will you be kind enough to to plot the MCD beta Poisson
just posted in the Rotavirus ScratchPad.
And attach the work sheet to familiarize doing.
Thanks in advance, Uni ... Jean
Stat Rotavirus [ScrathPad].sm (75kb) downloaded 36 time(s).
Offline uni
#346 Posted : 14 September 2018 20:21:56(UTC)
uni
Something like this.
ZedGraph. Log Example.sm (41kb) downloaded 46 time(s).
Russia ☭ forever
Offline uni
#347 Posted : 14 September 2018 23:58:31(UTC)
uni
Originally Posted by: Razonar Go to Quoted Post
How can access to SMath variables? Seems that isn't with `::fun`
Updated. Maple region partially restored.
Maple Plot Region can't save properties. This is because I have not yet figured out how to use it. It can display a variety of information in various forms. But its use is not convenient for the user.
I have one idea - the use of templates. But it's a bit difficult to implement yet.
Edited by user 15 September 2018 01:02:29(UTC)  | Reason: Not specified
Russia ☭ forever
on 15/09/2018(UTC)
Offline uni
#348 Posted : 20 September 2018 23:20:34(UTC)
uni
For other side, the function Maple, even can take an string for parse it, don't accept intermediate variable nor functions definitions inside the string. For example, maple("a:=1: a + 1:" ) gives an error.
Updated.
Russia ☭ forever
on 21/09/2018(UTC)
Offline Razonar
#349 Posted : 21 September 2018 00:14:32(UTC)
Razonar
Uruguay
Was thanked: 821 time(s) in 519 post(s)
Updated.
What can I say? Thanks don't looks enough. With this improvement seems much more easier handle dsolve and a lot of other maple call's
Offline tomtit
#350 Posted : 26 September 2018 17:20:03(UTC)
tomtit
Hello Uni,
The maple wrapper plugin supplied with the new revision of Smath (099.6839) failed on the attached worksheet.
It looks like it hangs forever at maple(simplfy(f1(v),v)). The process can't be interrupted and canceled by ESC key.
I've attached the failed code and plugin's log file.
The previous version of the plugin with latest beta Smath still works fine on the example.
Thank you for your hard work on the plugin.
P.S.
I noticed that under Windows 10 the symbolic calculations became slower about 4 times!
Do you have any idea? Instead 14 seconds it takes now about 1 min.
maple_failed_099b6839.sm (26kb) downloaded 33 time(s).
log.txt (10kb) downloaded 25 time(s).
Edited by moderator 26 September 2018 17:30:44(UTC)  | Reason: Not specified
thanks 1 user thanked tomtit for this useful post.
on 27/09/2018(UTC)
Offline uni
#351 Posted : 26 September 2018 17:26:53(UTC)
uni
Can you attach the log file for this case?
I think the problem is not in maple function. If you toggle a breakpoint you'll see that maple function worked only once.
EDIT: Hm... or something happened inside maple().
Edited by user 26 September 2018 18:14:07(UTC)  | Reason: Not specified
Russia ☭ forever
Offline uni
#352 Posted : 26 September 2018 18:20:58(UTC)
uni
I found the bug but I can't update the plugin because server doesn't work now.
Russia ☭ forever
#353 Posted : 26 September 2018 19:44:16(UTC)
Win 7 ... 1.8 sec !!!
maple_failed_099b6839.sm (53kb) downloaded 34 time(s).
Offline uni
#354 Posted : 28 September 2018 12:27:53(UTC)
uni
P.S.
Updated. Try now.
Nice trick from the sheet above.
Edited by user 28 September 2018 18:22:42(UTC)  | Reason: Not specified
Russia ☭ forever
on 28/09/2018(UTC)
Offline tomtit
#355 Posted : 28 September 2018 20:48:05(UTC)
tomtit
Clap Plugin works fine now.
But in general symbolic calculations in Win7 is 4 times faster than Win10.
My home Win7 computer is older and slower than Win10 office one.
Offline uni
#356 Posted : 03 February 2019 22:49:29(UTC)
uni
Updated.
Code:
04.02.2019 0:51:08 [INFO ] [->] smath_diff(smath_el(`(beta)`,2)*x^2,x)
04.02.2019 0:51:08 [INFO ] [<-] 2*el(β,2)*x
Changes:
- copy/paste issue for the regions fixed;
- maple(): fixed issue with output parsing;
- refactored.
Edited by user 04 February 2019 00:04:46(UTC)  | Reason: Not specified
Russia ☭ forever
on 03/02/2019(UTC)
Offline tomtit
#357 Posted : 06 February 2019 01:28:38(UTC)
tomtit
Hello Uni,
The plugin is broken again since Smath v.6962 (I'm sure only with ..62 at the end).
I've spent half of an hour and located the issue.
It is a tiny piece of a big worksheet.
mapledoesntworksince6962.sm (22kb) downloaded 40 time(s).
Edited by user 06 February 2019 01:32:56(UTC)  | Reason: Not specified
Offline uni
#358 Posted : 06 February 2019 02:22:00(UTC)
uni
I can't see the maple() function here.
Russia ☭ forever
Offline tomtit
#359 Posted : 06 February 2019 04:00:40(UTC)
tomtit
Sorry, Uni, I'm confused.
But there is a problem with symbolic calculations in the new betas.
#360 Posted : 06 February 2019 05:13:20(UTC)
Looks working open 6179, though it may generate "type conversion error"
Guest (3)
