I'm not shure about BodePlot and TransferFunction. I think Maple V Release 5 does not support these functions. You must use something like this: Edited by user 14 September 2018 00:25:11(UTC)
OK but in Bode the graph should has logarithmic scale (and it misses the phase plot (not a problem)). Is there some graphs plugin that does logarithmic scale, without I have to simulate it? Edited by user 14 September 2018 10:20:11(UTC)
ZedGraph can do that. Edited by user 14 September 2018 11:45:24(UTC)
on 14/09/2018(UTC), on 14/09/2018(UTC)
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1127 time(s) in 723 post(s)
ilt.sm (19kb) downloaded 42 time(s). |
3 users thanked mkraska for this useful post.
on 14/09/2018(UTC), on 14/09/2018(UTC), on 14/09/2018(UTC)
Originally Posted by: uni ZedGraph can do that.
Will you be kind enough to to plot the MCD beta Poisson just posted in the Rotavirus ScratchPad. And attach the work sheet to familiarize doing. Thanks in advance, Uni ... Jean Stat Rotavirus [ScrathPad].sm (75kb) downloaded 36 time(s).
Originally Posted by: Razonar How can access to SMath variables? Seems that isn't with `::fun` Updated. Maple region partially restored. Maple Plot Region can't save properties. This is because I have not yet figured out how to use it. It can display a variety of information in various forms. But its use is not convenient for the user. I have one idea - the use of templates. But it's a bit difficult to implement yet. Edited by user 15 September 2018 01:02:29(UTC)
Originally Posted by: Razonar For other side, the function Maple, even can take an string for parse it, don't accept intermediate variable nor functions definitions inside the string. For example, maple("a:=1: a + 1:" ) gives an error. Updated. |
Joined: 28/08/2014(UTC) Posts: 1,361 Was thanked: 822 time(s) in 520 post(s)
Originally Posted by: uni Updated.
What can I say? Thanks don't looks enough. With this improvement seems much more easier handle dsolve and a lot of other maple call's Best regards. Alvaro
Hello Uni, The maple wrapper plugin supplied with the new revision of Smath (099.6839) failed on the attached worksheet. It looks like it hangs forever at maple(simplfy(f1(v),v)). The process can't be interrupted and canceled by ESC key. I've attached the failed code and plugin's log file. The previous version of the plugin with latest beta Smath still works fine on the example. Thank you for your hard work on the plugin. P.S. I noticed that under Windows 10 the symbolic calculations became slower about 4 times! Do you have any idea? Instead 14 seconds it takes now about 1 min. maple_failed_099b6839.sm (26kb) downloaded 33 time(s). log.txt (10kb) downloaded 25 time(s).Edited by moderator 26 September 2018 17:30:44(UTC)
1 user thanked tomtit for this useful post.
Originally Posted by: tomtit The previous version of the plugin with latest beta Smath still works fine on the example. Can you attach the log file for this case? I think the problem is not in maple function. If you toggle a breakpoint you'll see that maple function worked only once. EDIT: Hm... or something happened inside maple(). Edited by user 26 September 2018 18:14:07(UTC)
I found the bug but I can't update the plugin because server doesn't work now. |
Originally Posted by: tomtit Do you have any idea? Instead 14 seconds it takes now about 1 min. Win 7 ... 1.8 sec !!! maple_failed_099b6839.sm (53kb) downloaded 34 time(s).
Originally Posted by: tomtit P.S. I noticed that under Windows 10 the symbolic calculations became slower about 4 times! Do you have any idea? Instead 14 seconds it takes now about 1 min. Updated. Try now. Nice trick from the sheet above. Edited by user 28 September 2018 18:22:42(UTC)
Plugin works fine now. But in general symbolic calculations in Win7 is 4 times faster than Win10. My home Win7 computer is older and slower than Win10 office one.
Updated. Code:04.02.2019 0:51:08 [INFO ] [->] smath_diff(smath_el(`(beta)`,2)*x^2,x)
04.02.2019 0:51:08 [INFO ] [<-] 2*el(β,2)*x
Changes: - copy/paste issue for the regions fixed; - maple(): fixed issue with output parsing; - refactored. Edited by user 04 February 2019 00:04:46(UTC)
Hello Uni, The plugin is broken again since Smath v.6962 (I'm sure only with ..62 at the end). I've spent half of an hour and located the issue. It is a tiny piece of a big worksheet. Best regards mapledoesntworksince6962.sm (22kb) downloaded 40 time(s).Edited by user 06 February 2019 01:32:56(UTC)
I can't see the maple() function here. |
Sorry, Uni, I'm confused. But there is a problem with symbolic calculations in the new betas.
Originally Posted by: tomtit The plugin is broken again since Smath v.6962 Looks working open 6179, though it may generate "type conversion error"
