1) You say "save as template" - what do you mean ? as I don't see any 'template' type in SMath.
Do you mean save as a normal file & treat this as a template for future use ? i.e. use this to
start any new calc following with a 'Save as' ?
2) Can you explain, please, the relationship between the background image, the logo image, header text,
and what 'pushes' the calculations down off the top of the page so that they paginate & flow correctly
within the body of the calcs page.
Sorry if I've being a bit slow here ..
but if you can provide detailed explanations step by step would be gratefully appreciated ..
3) I'm happy to send a sample calc page, but am not sure how to upload a resource.
=====================================1. From a blank work sheet, compose your cartouche [logo, text project ...],
then "save as" My Cartouche [typical or else named per your preference]
3. When your read a forum message, you can select "Quick Reply" , you can only
reply by text. It has no option to upload document. If you want to reply and
upload a document [Smath work sheet, *.PDF, snippet image ...], go at bottom
right and click on the caption
Post Reply. That will give the main forum menu
From the main menu, click on the
Paper clip to bring the upload file system
From
Add file, reach where your document is located in your computer ... double click
You can upload lot of different documents, within the forum acceptance documents don't sum > 5 MB.
Once you have finished adding document, click
Upload files.
At this point, you can review the text message and stack the attachments ... click in the
front of each bracketed [Attach ... ] press Enter . That will stack the uploaded documents.
3. How to get the background color in the Picture region that composes your cartouche is
undocumented. I know how to do because I did, but don't recall ... stupid enough !
In the collapsed area, you can copy/paste this picture area in Smath blank sheet and
compose from there. Just brush the mouse pointer over that region [just to enter]
Click on the BackGround icon from the main menu and define your background color.
You can have 256^3 different colors [16777216 ... is that enough ?].
Please, don't hesitate for more information.
Template Cartouche.sm (20kb) downloaded 39 time(s). ... rescued version
mostly for the model Picture Region in collapsed area
