SMath Studio Forum
Feature Requests
Speed matrix creation and filling with comma
When creating a new matrix, it would be faster, and more natural to type ctrl+m 2,3 <return> rather than use both row and column fields For me personally, the default for columns would best be 1, that is what I use more often than anything else. I also find filling matrices slow and difficult. It would be much easier to comma delimit data in columns, and semi-colon delimit rows. This would make it easy to fill either across or down. When reaching the end of a row/column, it would wrap to the next (regardless of "," or ";" ) The problem with tab is that it is with keys 1,2,3 + tab is it's a left hand cack handed stretch to the tab key that gets capslock every time, for me. - so I have to do it slowly. Using comma is left-right-left-right and flows smoothly. (This is the same reason that // is my favourite comment character regardless of language - it flows whereas eg. shift+# never does) Edited by user 05 May 2018 08:23:10(UTC)
| Reason: Added: use comma and ; for data entry as well as creation
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,649 Location: Italy Was thanked: 1333 time(s) in 877 post(s)
Currently empty matrix creation is CTRL+ M #rows TAB #columns RETURN (6 keystokes like in your suggestion) - BTW ^ is already assigned to the exponentiation operator Edited by user 04 May 2018 12:11:58(UTC)
Originally Posted by: crun For me personally, the default for columns would best be 1, that is what I use more often than anything else. ... at will, wherever ... ONE keystroke. Fill manually or address.
SMath Studio Forum
Feature Requests
