2 Pages12>
Offline Basile
#1 Posted : 22 February 2018 20:43:29(UTC)
Basile
Was thanked: 8 time(s) in 7 post(s)
Can I gave the angle of the polar form displayed directly in degrees?
Is there a solution to reporting the rectangular form with real and imaginary parts?
Thank you,
Basile
Offline Razonar
#2 Posted : 23 February 2018 10:36:39(UTC)
Razonar
Uruguay
Was thanked: 818 time(s) in 518 post(s)
Hi Basile.
I guess that you can't.
Even you can redefine those functions
degrees are dimensionless, and disappear as unit when you use them
So, you can introduce them into the definition, but don't appear in the answer, like meters, so, guess that it could be a bad idea introducing because you don't see them in the answer.
on 23/02/2018(UTC)
#3 Posted : 23 February 2018 17:13:11(UTC)
Not sure what you are after ?
[x:=3,y:=6] => arg(x+y*i) ...
Cartesian2Complex [x:=3,y:=6] => (x+y*i)
Maths xy2pol.sm (90kb) downloaded 68 time(s).
Offline Basile
#4 Posted : 23 February 2018 22:29:30(UTC)
Basile
Jean,
I do not get the graphs!
Basile
#5 Posted : 23 February 2018 23:41:14(UTC)
Jean,
Basile
Simple: if "U_ not defined" ... because [x,X] not defined
conclusion: your ODESOLVER plugin NOT installed.
Offline CBG
#6 Posted : 23 February 2018 23:46:54(UTC)
CBG
Hello Basile:
It seems that Smath Studio current version is working very erratically.
I also had the same problem with graphics, and sometimes they appear and sometimes they do not.
I did the following: I opened the file of Jean, and the graphs appear without graphing anything
and box in red, deactivate the Maxima plugin, and I recalculated the file, and then the graphics appeared.
I close the file and the program.
Again I open the program and the file, the graphics can appear or not, if they do not appear,
then I enable the Maxima plugin and then the graphics appear again.
It seems that the Maxima plugin is causing the problem.
What's going on?
Carlos
Offline mkraska
#7 Posted : 24 February 2018 00:53:43(UTC)
mkraska
Was thanked: 1127 time(s) in 723 post(s)
Can't reproduce the problem
Offline CBG
#8 Posted : 24 February 2018 01:44:41(UTC)
CBG
That's why I say that Smath Studio is running very erratically, in the drawing
I show 2 different runs of the same file on the same computer with the same
version but with different results.
How have I arrived at these results?
In the first case, I open Smath Studio in a normal way with all the plugins activated,
I open the file, and the result is that it does not graph.
For the second case, I open Smath Studio, I disable the Maxima Plugin, I open the file,
and then the program correctly graphs, I close the file and the program. I open the program
again and activate the Maxima Plugin, now I open the file, and then it graphs correctly again.
I do not know what may be causing this erratic behavior.
Best regardas
Carlos
Offline CBG
#9 Posted : 24 February 2018 02:15:27(UTC)
CBG
I found the real cause of the problem, and it is the decimal separator,
If you use the period as a decimal separator, then the program causes error and not graphics.
If you use the comma as a decimal separator, then there is no problem
Carlos
Offline Basile
#10 Posted : 24 February 2018 03:45:24(UTC)
Basile
Jean,
It is installed.
Basile
Offline CBG
#11 Posted : 24 February 2018 05:23:29(UTC)
CBG
Basile,
In options, change the decimal separator from "Point" to "Comma", (from "." To ","Wink
With that change, the file works correctly.
Carlos
Offline Basile
#12 Posted : 24 February 2018 06:39:51(UTC)
Basile
Carlos,
It did not work for me.
Basile
Offline CBG
#13 Posted : 24 February 2018 08:39:33(UTC)
CBG
Basile
Try disabling the Maxima plugin, that may work.
Best regard
Carlos
Offline Basile
#14 Posted : 25 February 2018 05:52:04(UTC)
Basile
SMath-08.PNGCarlos,
It does not work for me.
Basile
#15 Posted : 25 February 2018 06:56:21(UTC)
Jean,
It is installed.
Basile
Your box [PC] may be freaked...
Not from clean purchase, games ...
At this point of all tests, there is no other explanation.
Offline Basile
#16 Posted : 26 February 2018 01:13:20(UTC)
Basile
Jean,
You never know...
Basile
#17 Posted : 26 February 2018 02:29:32(UTC)
Jean,
You never know...
Basile
You are right but I remember too many thanks from Mathsoft Collaboratory
hints: illegal PC, illegal Mathcad, unprotected visits [mostly caused by
not Auto Win updates], poor legal games that convert PC => XBox and don't
return to Win user ... illegal games [assured killer... reinstall legal
Win version from CD on same machine].
My little finger is called "spy finger" !
I'm not "Doctor Who/What".
Offline CBG
#18 Posted : 27 February 2018 00:28:21(UTC)
CBG
Hello Basile:
Why not try to run the file in a portable version of Smath Studio like Martin Kraska's?
Carlos
Edited by moderator 27 February 2018 19:37:52(UTC)  | Reason: Not specified
#19 Posted : 27 February 2018 17:20:11(UTC)
Server Error in '/' Application.
Maybe under maintenance ?
Maybe I should have portable 6179 on my XP
Edited by moderator 27 February 2018 19:37:34(UTC)  | Reason: link fixed
Offline mkraska
#20 Posted : 27 February 2018 18:56:05(UTC)
mkraska
The correct link is found in my signature, you can also go to the wiki and search for "portable".
There is no update yet for the current stable release. I am busy with adjusting the docs.
Similar Topics
Plotting a x,y graph with complex numbers (Questions)
by Lee Snook 06/07/2023 22:42:28(UTC)
Is there a way to get ride of complex numbers? (Questions)
by 009jim 26/05/2021 07:18:59(UTC)
pi in complex numbers (Bugs & Problems)
by krissn 28/10/2018 23:23:03(UTC)
Missing bracket in display of complex numbers with changed units (Bugs & Problems)
by mkraska 26/06/2013 09:30:13(UTC)
Angles of complex numbers with units (Feature Requests)
by identical 26/06/2012 21:44:39(UTC)
Programmer palette and complex numbers (Bugs & Problems)
by marcin 07/03/2011 13:19:02(UTC)
2 Pages12>
