Was thanked: 8 time(s) in 7 post(s)
Hello, Can I gave the angle of the polar form displayed directly in degrees? Is there a solution to reporting the rectangular form with real and imaginary parts? Thank you, Basile
Joined: 28/08/2014(UTC) Posts: 1,359 Was thanked: 819 time(s) in 518 post(s)
Hi Basile. I guess that you can't. Even you can redefine those functions degrees are dimensionless, and disappear as unit when you use them So, you can introduce them into the definition, but don't appear in the answer, like meters, so, guess that it could be a bad idea introducing because you don't see them in the answer. Best regards. Alvaro
Originally Posted by: Basile Hello, Can I gave the angle of the polar form displayed directly in degrees? Is there a solution to reporting the rectangular form with real and imaginary parts? Not sure what you are after ? [x:=3,y:=6] => arg(x+y*i) ... Cartesian2Complex [x:=3,y:=6] => (x+y*i) Maths xy2pol.sm (90kb) downloaded 68 time(s).
Jean, I do not get the graphs! Basile
Originally Posted by: Basile Jean, I do not get the graphs! Basile Simple: if "U_ not defined" ... because [x,X] not defined conclusion: your ODESOLVER plugin NOT installed.
Hello Basile: It seems that Smath Studio current version is working very erratically. I also had the same problem with graphics, and sometimes they appear and sometimes they do not. I did the following: I opened the file of Jean, and the graphs appear without graphing anything and box in red, deactivate the Maxima plugin, and I recalculated the file, and then the graphics appeared. I close the file and the program. Again I open the program and the file, the graphics can appear or not, if they do not appear, then I enable the Maxima plugin and then the graphics appear again. It seems that the Maxima plugin is causing the problem. What's going on? Best Regards Carlos
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1127 time(s) in 723 post(s)
Can't reproduce the problem |
That's why I say that Smath Studio is running very erratically, in the drawing I show 2 different runs of the same file on the same computer with the same version but with different results. How have I arrived at these results? In the first case, I open Smath Studio in a normal way with all the plugins activated, I open the file, and the result is that it does not graph. For the second case, I open Smath Studio, I disable the Maxima Plugin, I open the file, and then the program correctly graphs, I close the file and the program. I open the program again and activate the Maxima Plugin, now I open the file, and then it graphs correctly again. I do not know what may be causing this erratic behavior. Best regardas Carlos
I found the real cause of the problem, and it is the decimal separator, If you use the period as a decimal separator, then the program causes error and not graphics. If you use the comma as a decimal separator, then there is no problem Best Regards Carlos
Jean, It is installed. Basile
Basile, In options, change the decimal separator from "Point" to "Comma", (from "." To "," With that change, the file works correctly. Best Regards Carlos
Carlos, It did not work for me. Basile
Basile Try disabling the Maxima plugin, that may work. Best regard Carlos
Carlos, It does not work for me. Basile
Originally Posted by: Basile Jean, It is installed. Basile Your box [PC] may be freaked... Not from clean purchase, games ... At this point of all tests, there is no other explanation. Jean
Jean, You never know... Basile
Originally Posted by: Basile Jean, You never know... Basile You are right but I remember too many thanks from Mathsoft Collaboratory hints: illegal PC, illegal Mathcad, unprotected visits [mostly caused by not Auto Win updates], poor legal games that convert PC => XBox and don't return to Win user ... illegal games [assured killer... reinstall legal Win version from CD on same machine]. My little finger is called "spy finger" ! I'm not "Doctor Who/What".
The correct link is found in my signature, you can also go to the wiki and search for "portable". There is no update yet for the current stable release. I am busy with adjusting the docs. |
