3 Pages<123>
#21 Posted : 17 April 2016 20:46:33(UTC)
Originally Posted by: ElSid Go to Quoted Post
Does this or any other "excel" plugin work with "ods" extensions? I am on Libre office on both Windows and Linux at home. I could not get to work.
Look here: Data Exchange plugin
Offline MichaelSA
#22 Posted : 27 August 2017 10:58:51(UTC)
MichaelSA
South Africa
Hi Davide,
I had successfully used the plug-in until Excel 2016 / Windows 10 (or both).
Re-using Smath code (very simple - single line, single cell import), I get an error:
"The 'br' start tag on line 767 does not match the end tag of 'front'. Line 768. position 9."
Could you advise where I could start de-bugging / looking for a solution?
Otherwise an awesome plug-in (until MS changed something Sad ).
Thanks and kind regards,
Michael
#23 Posted : 27 August 2017 19:06:52(UTC)
I've made a survey on the Github of the plugin that handle the worksheets and seems something that might happens when a graph or an object contains multiline text, but cannot be fixed from inside that plugin. I might try to provide a fix from inside our plug-in; could you share the worksheet that cause the issue? (if cannot be published you can send me a PM or a mail).
Offline MarB
#24 Posted : 29 January 2018 11:10:06(UTC)
MarB
I recognize some problems importing an excel-sheet.
I use , as decimal point.
If an excel sheet contains numbers with decimal point, importing fails. ( "The stack is empty." )
If I put a = before each number with point/comma, then it works.
Changing the settings in Excel does not work.
With the setting using point as 'decimal point" in Smath it works as in older versions.
Please have a look at the screenshots below:
thanks 1 user thanked MarB for this useful post.
on 29/01/2018(UTC)
#25 Posted : 29 January 2018 13:27:21(UTC)
Thank you very much, bug reproduced and hopefully fixed Good
PLUGIN UPDATED
Offline MarB
#26 Posted : 29 January 2018 14:41:17(UTC)
MarB
I am the one who has to thank you. It works.
Offline mikka
#27 Posted : 07 February 2018 15:20:57(UTC)
mikka
Good day, it is not possible to get data from the excel from cells B6 and E6. File excel attached my SMath XLSX input.xlsx (12kb) downloaded 52 time(s).
#28 Posted : 07 February 2018 16:16:29(UTC)
The problem here is that the I/O syntax of this plugin I've defined
Code:
="something"
as the way to import/export symbolical data
Code:
"something"
as the way to import/export math strings
therefore you can't use excel string chaining, since it is interpreted as symbolic data.
I guess that this feature is marginal enough to safely change it and set both the cases to import stuff as strings, then one can still use str2num() to convert to symbolic math, but I'm not sure about how this impact existing worksheets. Let's hear if someone in the community has some major concerns about this change.
Edited by user 07 February 2018 16:24:10(UTC)  | Reason: Not specified
on 08/02/2018(UTC)
Offline mikka
#29 Posted : 08 February 2018 08:31:06(UTC)
mikka
I need to get the text data from the excel, which are generated by formulas ...
#30 Posted : 08 February 2018 19:05:01(UTC)
Ignore mycomment.
In short, I don't understand why Excel is still delivered with Windows.
My Win 7 laptop "Starter Edition" does not even have Word, Excel [Paint; piece of crap].
If you generate/tabulate data in Excel, it comes from formulas and cells referenced/dragged.
You can generate same data in Smath.
The attached will create CWD:="C:\SmathFile" to read from your download.
Smath file system allows to save formulas [no limit],
read them back ... an example given.
text data ... you mean to read Excel numerical data <= back in Smath as Text,
but why ? Maybe to make an image as frozen stuff for sharing ???
Smath 6179
File READ First.sm (23kb) downloaded 72 time(s).
on 09/02/2018(UTC)
#31 Posted : 11 February 2018 22:10:11(UTC)
Beta PLUGIN UPDATED SMath Studio 0.99.6611 Beta
- All text cells are now imported as text (import of symbolic data still possible with built-in str2num() function);
- Fixed import of empty strings;
- Fixed import of some exponential numbers;
Edited by user 12 February 2018 01:15:01(UTC)  | Reason: wrong target version
thanks 3 users thanked Davide Carpi for this useful post.
on 11/02/2018(UTC),  on 11/02/2018(UTC),  on 13/02/2018(UTC)
Offline mikka
#32 Posted : 13 February 2018 10:05:02(UTC)
mikka
Thanks, everything works well Good
Edited by user 13 February 2018 11:06:04(UTC)  | Reason: Not specified
Offline chon
#33 Posted : 05 June 2018 18:15:49(UTC)
chon
Hey. I have mistake. Not read cells with dual address.
For example:
1. exit: import Data.XLSX (File_Data,"Source","X4","AH4"Wink - does not import.
2. exit: importData.XLSX(File_Data,"Source","X4", "A4"Wink - imports.
That is, the difference in the address "A4" or " A4 " - with a double letter does not import.
v. 1.1.6616.19995
source.7z (43kb) downloaded 37 time(s).
Edited by user 05 June 2018 18:31:49(UTC)  | Reason: Not specified
Offline kadpeter
#34 Posted : 13 August 2018 13:48:29(UTC)
kadpeter
Rank: Member
Hungary
I found a failure with XLSX Import/Export plugin using in our national settings (Hungarian). We use "," as decimal symbol in Excel and in SMath too.
If I export 5/4 or '0,8' to Excel, I'll get '0.8' (string). If I export 6/4, I'll get '2018.01.02' (date).
If I import '="2.54*{'kN/'m}"' from Excel, I'll get '="2.54*{'kN/'m}"' (not '2,54 kN/m'Wink.
If I import '="2,54*{'kN/'m}"' from Excel, I'll get '="2,54*{'kN/'m}"'.
But if I import '0,8' (number) from Excel, I'll get '0,8' value (wich is correct).
Peter Kaderasz
#35 Posted : 13 August 2018 20:57:14(UTC)
For example:
v. 1.1.6616.19995
Sorry for the late answer, I've totally missed this report.
When I open your file I see this:
And if I change it with AH4 I get the result:
I'll inspect the exeption thrown by AP4 however.
Peter Kaderasz
Hello, I'll inspect it ASAP (and if your able to provide a small file with these example it would help too Good)
Offline kadpeter
#36 Posted : 15 August 2018 09:53:33(UTC)
kadpeter
Rank: Member
Hungary
Hello Davide,
I've tried the examples from the plugin's documentation (https://en.smath.info/forum/yaf_postst1860_Xlsx-Import-Export-plugin.aspx).
Here is a picture (this time I modified '4/5' to '6/5', you can see that this value imported to Excel as '2018.01.02' in our date format 'yyyy.mm.dd'Wink:
Other numerical values, f.e. '-57,1' and 'sin(2^(1/2)) imported to Excel as string, so we can't do mathematical operations with these values.
Peter Kaderasz
Edited by moderator 23 October 2018 21:51:13(UTC)  | Reason: Not specified
#37 Posted : 24 October 2018 01:32:06(UTC)
PLUGIN UPDATED SMath Studio 0.99.6839 and later
- fixed export as text/date of numbers;
release deleted
Edited by user 24 October 2018 19:35:45(UTC)  | Reason: Not specified
#38 Posted : 25 October 2018 19:09:46(UTC)
  • fixed export as text/date of numbers;
  • fixed previous commit issues on extension's download;
  • migration to netstandard2.0/netcoreapp2.0
#39 Posted : 22 November 2018 20:27:36(UTC)
Beta PLUGIN UPDATED SMath Studio 0.99.6884 and later
Office Open XML I/O library changed from ClosedXML to EPPlus
Advantages:
  • better compatibility with non compliant xml schema (f.e. issues with newline in post #22 or here);
  • smaller library size;
  • works in SMath Viewer;
  • easier coding;
Edited by user 23 November 2018 02:44:47(UTC)  | Reason: Not specified
thanks 5 users thanked Davide Carpi for this useful post.
on 22/11/2018(UTC),  on 22/11/2018(UTC),  on 23/11/2018(UTC),  on 23/11/2018(UTC),  on 24/11/2018(UTC)
Offline mikka
#40 Posted : 29 January 2019 08:10:02(UTC)
mikka
Hello, stopped working import from xlsx file.
lastError = " Variable and function names can't start with a number. File attached
test.sm (8kb) downloaded 30 time(s).
Edited by user 29 January 2019 08:13:53(UTC)  | Reason: Not specified
Guest (2)
3 Pages<123>
