3 Pages123>
#1 Posted : 10 June 2013 10:49:00(UTC)
Was thanked: 1180 time(s) in 776 post(s)
SMath Studio compatibility SMath Viewer compatibility mono compatibility
extension page Sources MIT license
Here there is a plugin to share data between SMath and XLSX Spreadsheets (*.xlsx, *.xlsm).
Plugin UI languages: English Deutsch Italiano Русский Español
PLEASE REPORT IN THIS TOPIC ANY ISSUE.
  • requirements: SMath Studio 0.96.4909 or later, .Net Framework 3.5 (Windows) / Latest Mono distributive (Linux);
  • installation: download the plugin from the gallery;
  • documentation: XlsxImportExport_docs.7z (39kb) downloaded 756 time(s).;
  • languages: if you want to have a new UI language look into the documentation's Language folder.
Attached below OLD documentation for SMath Studio prior to 0.97.5346 (0.96.4909 <= SS < 0.97.5346)
Edited by user 17 November 2018 20:26:38(UTC)  | Reason: Not specified
File Attachment(s):
XlsxImportExport_docs.7z (38kb) downloaded 738 time(s).
thanks 9 users thanked Davide Carpi for this useful post.
on 10/06/2013(UTC),  on 10/06/2013(UTC),  on 10/06/2013(UTC),  on 10/06/2013(UTC),  on 10/06/2013(UTC),  on 10/06/2013(UTC),  on 17/01/2016(UTC),  on 07/12/2016(UTC),  on 11/01/2018(UTC)
#2 Posted : 10 June 2013 12:07:53(UTC)
thank you for the feedback Friends Good
best regards,
Davide
Offline genf
#3 Posted : 10 June 2013 13:45:09(UTC)
genf
Was thanked: 5 time(s) in 5 post(s)
How to use this plugin - did not quite understand. Thank you.
#4 Posted : 10 June 2013 13:50:31(UTC)
Examples added to the first post (XlsxImportExport_docs.7z - nothing changes in the usage from those contained in the previous Data Exchange plugin) Good
Attached here a pdf to show the expected output.
regards,
w3b5urf3r
Edited by user 10 June 2013 14:01:49(UTC)  | Reason: Not specified
File Attachment(s):
Xlsx Import_Export examples.pdf (63kb) downloaded 1,123 time(s).
on 10/06/2013(UTC)
Offline mkraska
#5 Posted : 10 June 2013 14:03:52(UTC)
mkraska
Was thanked: 916 time(s) in 575 post(s)
All plugin functions are explained in the function reference part of the handbook (see signature). It is in german, but the examples should be self documenting (most of them in fact taken from Davide's examples)
on 10/06/2013(UTC)
Offline Ernesto
#6 Posted : 03 February 2014 06:52:57(UTC)
Ernesto
Nicaragua
Was thanked: 13 time(s) in 11 post(s)
I tried this plugin out, since importing and exporting to excel would be extremely useful.
However when I try to import a cell with a function referencing another cell, the cell reference is imported (eg: A5*G4), instead of the value of the cell. Is there any way around this?
Also, is it possible to export to an existing excel file, without overwriting it? I tried exporting to an existing file, and everything in the file gets erased, except for the newly exported data.
Thanks,
Ernesto.
Edited by user 03 February 2014 08:42:55(UTC)  | Reason: Not specified
#7 Posted : 03 February 2014 20:56:49(UTC)
I need to see the ClosedXML API references...
About cell's references if I remember correctly there are some limitations (not all the functions are supported and not all the references, f.e. between different sheets) but I can check if something can be made...
For both the things, I'll see what I can do Good
Edited by user 03 February 2014 21:10:44(UTC)  | Reason: Not specified
Offline RFreund
#8 Posted : 06 April 2014 16:49:33(UTC)
RFreund
Was thanked: 18 time(s) in 16 post(s)
In the example file it is stated
Quote:
import a single cell
(file in the same folder of this sheet; use a relative/absolute path otherwise)
Does this mean if the file is in the same folder as SMath?
It appears that the program looks where the Smath.exe file is stored is that correct?
Thanks
EDIT:
I wanted to use the folder where the calulcation page and the excel sheet was stored. Therefore I should first set CurrentDirectory(DocumentDirectory(""Wink)
Edited by user 06 April 2014 16:54:15(UTC)  | Reason: Not specified
#9 Posted : 06 April 2014 17:48:17(UTC)
The "base" path is the path of the worksheet, if available (existing worksheet) otherwise is the user "Documents" folder.
The archive in the first post contains some import/export examples.
BTW the path of the executable has no much interest (in most of the cases the user don't know where it is or needs administration privileges to write inside it)
Best regards,
Davide
Edited by user 06 April 2014 17:51:58(UTC)  | Reason: Not specified
Offline mkraska
#10 Posted : 18 May 2014 18:45:37(UTC)
mkraska
Is the Excel import meant to be Viewer-safe? I get the attached error message if I try to run a viewer application with excel read. With ods-format the situation is similar.
File Attachment(s):
MB.zip (20kb) downloaded 100 time(s).
#11 Posted : 19 May 2014 01:12:19(UTC)
To be honest, I've never tried these plugins in SMath Viewer; seems that the external assemblies are not embedded in the Viewer.
As secondary thing reading the ClosedXML/Ionic.Zip licenses I suppose that any Viewer executable shall contains the relative copyright notice, and this actually is not possible (if this is not made by you manually)...
Edited by user 19 May 2014 01:34:42(UTC)  | Reason: Not specified
on 19/05/2014(UTC)
Offline mkraska
#12 Posted : 19 May 2014 21:49:19(UTC)
mkraska
I try to setup a data browser for use by my colleagues, therefore any hints on how to do viewer-safe data import of spreadsheets are welcome. Perhaps this could be done within excel, but I am not comfortable with it and just use the opportunity to do some SMath testing.
#13 Posted : 20 May 2014 01:07:46(UTC)
Nice idea...
Added in the BTS as SV-146 and SV-147
Best regards,
Davide
Offline msiseminger
#14 Posted : 05 August 2014 18:56:26(UTC)
msiseminger
Davide,
The issue with "DocumentFormat.OpenXml.dll" not found when you create and run an .exe can be resolved by removing the reference to the .dll from the "References" section in your extention solution. You do not call this .dll anywhere in the extension so it is not needed. When I do this, I no longer get the missing .dll error.
The .exe still does not pull in the Excel spreadsheets I want with the missing .dll error fixed. I did do further investigation and the .exe program can not handle even a simple mat() function by itself with no other references. This lead me to believe that the .exe program is at issue and not your extension.
Mike
thanks 1 user thanked msiseminger for this useful post.
on 05/08/2014(UTC)
#15 Posted : 07 March 2015 16:05:02(UTC)
PLUGIN UPDATED
- ImportData.XLSX now get results where cells references other cells;
- fixed export on SMath Viewer;
Offline Alex M.
#16 Posted : 11 March 2015 21:26:49(UTC)
Alex M.
Was thanked: 119 time(s) in 92 post(s)
I figured this conversation is best to be continued here
Originally Posted by: w3b5urf3r_reloaded Go to Quoted Post
COM plugins are a unexplored field for me. My first idea is to have something like a Calculate.MSExcel("file") / Calculate.LOCalc("file") functions; I don't know if this is possible for the whole document, anyway should be possible for a range Calculate.XYZ("file","cells").
Base documentation:
- for excel: How to: Run Excel Calculations Programmatically
- for LO: SDK 4.3: Common Language Infrastructure (CLI) examples
Is it possible to run visual basic script from your plugin? I have come up with (pieced together from numerous online sources) a .vbs file that will update (in background) all the XLSX files in the directory it is run from (it will actually run a background EXCEL process that can be tasked to do anything excel can). If this or similar could be incorporated in your plugin I can see following happening:
1. Modify "input" xlsx workbook using your data exchange plugin
2. Run .vbs script that will recalculate/save all workbooks linked to input work book (I wonder if it is possible to somehow start the sript from within Smath)
3. Export cell range from desired workbook
I am sure with .vbs there is a way to perform all input - calculations - output strictly in memory, so no files need to be saved unless desired. I am not sure, however, if it is something that can be used by a Smath Studio plugin.
Edited by user 11 March 2015 22:37:13(UTC)  | Reason: Not specified
File Attachment(s):
Update - CurrentDir - All.vbs.txt (1kb) downloaded 90 time(s).
SpreadSheet IOxlsx.7z (12kb) downloaded 96 time(s).
#17 Posted : 25 June 2015 21:39:07(UTC)
PLUGIN UPDATED SMath Studio 0.97.5581
- import data: fixed bug when quotation mark (") is used in a cell, f.e. for inches measurements. Now this character is converted in the "Double Prime" character (″) [many thanks to Don Bollard for pointing out this bug];
- import data: importData.XLSX(3) now accepts a range of cells as third argument (f.e. "A3:B12");
Edited by user 26 June 2015 00:54:03(UTC)  | Reason: APIs updated to the latest NB version
#18 Posted : 20 January 2016 19:32:54(UTC)
PLUGIN UPDATED SMath Studio 0.97.5737
  • importData.XLSX() can access files opened by other processes (only saved data);
Edited by user 20 January 2016 19:34:50(UTC)  | Reason: Not specified
on 20/01/2016(UTC)
#19 Posted : 17 April 2016 13:43:28(UTC)
PLUGIN UPDATED SMath Studio 0.97.5346 and later
- added exportData.XLSX(4)* [extends exportData.XLSX(2)];
- added exportData.XLSX(5)* [extends exportData.XLSX(3)];
- importData.XLSX(...): fixes in path processing;
* How they works:
- If the file doesn't exists, a new file is created;
- If the sheet in the workbook doesn't exists, a new sheet is created;
- If the sheet exists in the workbook, data in the target cells will be overwritten; use these functions with caution if your output may have a different size at each run;
Edited by user 17 April 2016 13:52:26(UTC)  | Reason: typo
Offline ElSid
#20 Posted : 17 April 2016 20:44:14(UTC)
ElSid
Was thanked: 12 time(s) in 11 post(s)
Does this or any other "excel" plugin work with "ods" extensions? I am on Libre office on both Windows and Linux at home. I could not get to work.
3 Pages123>
