2 Pages<12
Offline kilele
#21 Posted : 27 March 2014 22:30:38(UTC)
kilele
It has occurred to me that the plugin could send the bin data to the clipboard and then the user could make a paste (control-v) by hand into any folder (as the program HTMtied does)
Another alternative could be using DDE as a layer between windows programs, see:
http://jdde.pretty-tools.com/
http://www.thescarms.com/VBasic/ddeml.aspx
Edited by user 27 March 2014 22:59:07(UTC)  | Reason: Not specified
on 27/03/2014(UTC)
Offline kilele
#22 Posted : 28 March 2014 02:42:35(UTC)
kilele
have you tried to write to the %TEMP% or %APPDATA% directories ?
Edited by user 28 March 2014 02:44:43(UTC)  | Reason: Not specified
on 28/03/2014(UTC)
Offline mkraska
#23 Posted : 28 March 2014 10:25:09(UTC)
mkraska
Perhaps the function GetFolderPath() can help.
on 28/03/2014(UTC)
Offline kilele
#24 Posted : 28 March 2014 13:00:10(UTC)
kilele
Ioan, i'm not sure to understand the problem well
perhaps you can use DAvide's hyperlink plugin
on 28/03/2014(UTC)
Offline kilele
#25 Posted : 28 March 2014 16:25:05(UTC)
kilele
don't ask me why but i think that'll work if you place the sm files at the same directory as smath exe
on 28/03/2014(UTC)
Offline kilele
#26 Posted : 28 March 2014 19:30:28(UTC)
kilele
the two large buttons at the bottom are green in my case, tested with martin's portable version on xp
on 28/03/2014(UTC)
Online uni
#27 Posted : 25 April 2014 01:15:34(UTC)
uni
Was thanked: 1275 time(s) in 746 post(s)
Updated. Play() function now works as expected (it waits for the end of sound).
Russia ☭ forever
Viacheslav N. Mezentsev
on 25/04/2014(UTC)
Offline 9_82abZ2
#28 Posted : 15 September 2015 20:37:12(UTC)
9_82abZ2
This is as good a place as any:
Is there a function that returns the filename of the current worksheet/Smath Document? I couldn't find it
Offline MarB
#29 Posted : 07 June 2017 10:12:30(UTC)
MarB
Currently I have the same question and also no answer (and couldn't find one).
Can anybody help?
#30 Posted : 07 June 2017 21:20:56(UTC)
Originally Posted by: MarB Go to Quoted Post
Is there a function that returns the filename of the current worksheet/Smath Document?I couldn't find it
Simple but not so simple, EXPLAIN:
1. If your work sheet resides in a subfolder: don't know if possible [didn't find trick]
2. If your work sheet reside in a folder in "C:\ ==> like this
path:=CurrentDirectory(""Wink
path="C:\Smath6179\"
#31 Posted : 08 June 2017 03:42:05(UTC)
Offline MarB
#32 Posted : 08 June 2017 09:16:49(UTC)
MarB
Hi Jean,
I do know 'CurrentDirectory( "" )' but it returns the path without the filename. And I am trying to retrieve the latter.
#33 Posted : 08 June 2017 14:38:18(UTC)
If I open a work sheet from "My Computer, C, click on the Folder, click on the work sheet
it will open Smath and CWD= is from which folder the work sheet comes from [Snippet].
Differently, If I open Smath first from the task bar, and click on the file name from the
file list on the Smath menu, I get: CWD="C\Program Flies\Smath Studio"
In fact, my Smath is so simple ... all my 925 work sheets are piled in Smath6179 folder.
All in all => same as Mathcad 11
Online uni
#34 Posted : 08 June 2017 15:05:42(UTC)
uni
Can anybody help?
As workaround you can use simple C# script for this (Script plugin).
Code:
store.AddDefinition( terms[0].Text, new Term[0], new Entry( "\"" + store.FileName + "\"" ) );
Russia ☭ forever
#35 Posted : 08 June 2017 17:46:34(UTC)
A more complete code would look like Mathcad 11
CWD="C:\Program Files\Mathsoft\Mathcad 11\Handbooks\datapack"
Offline mkraska
#36 Posted : 29 October 2019 11:05:48(UTC)
mkraska
The function getfolderpath() seems to be broken for build 7219:
getfolder.sm (3kb) downloaded 21 time(s).
on 31/10/2019(UTC)
Online uni
#37 Posted : 31 October 2019 20:05:49(UTC)
uni
Updated and rebuilded for SMath Studio ≥ 0.99.7109.
Russia ☭ forever
on 01/11/2019(UTC),  on 02/11/2019(UTC)
Offline oscampo
#38 Posted : 29 June 2021 14:08:28(UTC)
oscampo
Colombia
Was thanked: 87 time(s) in 66 post(s)
I found that the following functions of this plugin are not working:
Play(), WRITEWAV(), GETWAVINFO(), READWAV().
I saw the problem inside the interactive SMath Handbook.
I have SMath Studio 0.99.7822 (01 June 2021) on win10.
Oscar
thanks 1 user thanked oscampo for this useful post.
on 29/06/2021(UTC)
Online uni
#39 Posted : 29 June 2021 15:47:38(UTC)
uni
SMath Studio compatibility
Plugin updated. Please try.
Changes:
- plug-in corrected to respect latest SMath Studio API changes.
Edited by user 29 June 2021 15:51:38(UTC)  | Reason: Not specified
Russia ☭ forever
on 29/06/2021(UTC),  on 29/06/2021(UTC)
Similar Topics
[MathcadFileAccess] Read Image Puzzle (Bugs & Problems)
by Jean Giraud 21/02/2016 23:26:19(UTC)
2 Pages<12
