1 user thanked kilele for this useful post.
have you tried to write to the %TEMP% or %APPDATA% directories ? Edited by user 28 March 2014 02:44:43(UTC)
| Reason: Not specified
Perhaps the function GetFolderPath() can help. mkraska attached the following image(s): |
Ioan, i'm not sure to understand the problem well perhaps you can use DAvide's hyperlink plugin
don't ask me why but i think that'll work if you place the sm files at the same directory as smath exe
the two large buttons at the bottom are green in my case, tested with martin's portable version on xp
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,495 Was thanked: 1275 time(s) in 746 post(s)
Updated. Play() function now works as expected (it waits for the end of sound). |
This is as good a place as any:
Is there a function that returns the filename of the current worksheet/Smath Document? I couldn't find it
Originally Posted by: 9_82abZ2 This is as good a place as any:
Is there a function that returns the filename of the current worksheet/Smath Document? I couldn't find it Currently I have the same question and also no answer (and couldn't find one). Can anybody help?
Originally Posted by: MarB Is there a function that returns the filename of the current worksheet/Smath Document?I couldn't find it Simple but not so simple, EXPLAIN: 1. If your work sheet resides in a subfolder: don't know if possible [didn't find trick] 2. If your work sheet reside in a folder in "C:\ ==> like this path:=CurrentDirectory("" path="C:\Smath6179\"
Originally Posted by: Jean Giraud Originally Posted by: MarB Is there a function that returns the filename of the current worksheet/Smath Document?I couldn't find it path:=CurrentDirectory("" path="C:\Smath6179\" Hi Jean, I do know 'CurrentDirectory( "" )' but it returns the path without the filename. And I am trying to retrieve the latter.
Originally Posted by: MarB I do know 'CurrentDirectory( "" )' but it returns the path without the filename. And I am trying to retrieve the latter. If I open a work sheet from "My Computer, C, click on the Folder, click on the work sheet it will open Smath and CWD= is from which folder the work sheet comes from [Snippet]. Differently, If I open Smath first from the task bar, and click on the file name from the file list on the Smath menu, I get: CWD="C\Program Flies\Smath Studio" In fact, my Smath is so simple ... all my 925 work sheets are piled in Smath6179 folder. All in all => same as Mathcad 11 Cheers ... Jean
Originally Posted by: MarB Originally Posted by: 9_82abZ2 This is as good a place as any:
Is there a function that returns the filename of the current worksheet/Smath Document? I couldn't find it Currently I have the same question and also no answer (and couldn't find one). Can anybody help? As workaround you can use simple C# script for this (Script plugin). Code:store.AddDefinition( terms[0].Text, new Term[0], new Entry( "\"" + store.FileName + "\"" ) );
A more complete code would look like Mathcad 11
CWD="C:\Program Files\Mathsoft\Mathcad 11\Handbooks\datapack"
The function getfolderpath() seems to be broken for build 7219: getfolder.sm (3kb) downloaded 21 time(s).
SMath Studio: SMath Studio Desktop 0.99.7219.26345 portable, 64-bit OS: Microsoft Windows NT 6.1.7601 Service Pack 1; Windows 7 Professional Service Pack 1, 64-bit Screen: 1920x1080 px, 96x96 dpi, 96 GP.CDPI Localization: language=ENG; dec.symbol=<comma>; arg.separator=<semicolon>; OS dec.symbol=<comma>; OS arg.separator=<semicolon>; OS d.g.separator=<period> Framework: CLR 4.0.30319.42000
installed versions: v2.0.50727 2.0.50727.5420 SP2 v3.0 3.0.30729.5420 SP2 v3.5 3.5.30729.5420 SP1 v4 Client 4.7.02053 Full 4.7.02053 v4.0 Client 4.0.0.0
Plugins: - [AppDir] Area Region - 0.99.7219.26345 - [AppDir] HTMLFileType - 1.14.7219.26345 - [AppDir] ImageFileType - 1.11.7219.26345 - [AppDir] Math Region - 0.99.7219.26345 - [AppDir] PictureRegion - 1.10.7219.26345 - [AppDir] PlotRegion - 1.11.7219.26345 - [AppDir] SMath Viewer Files Plugin - 1.1.7219.26385 - [AppDir] SMathFileType - 1.11.7219.26345 - [AppDir] SpecialFunctions - 1.12.7219.26345 - [AppDir] SpecialFunctions - 1.12.7219.26345 - [AppDir] StandardToolboxButtons - 1.1.7219.26345 - [AppDir] TextRegion - 1.11.7219.26345 - [AppDir] XMCDFileType - 1.12.7219.26345 - [UserDir] Custom Functions - 1.1.7200.16172 - [UserDir] Custom Glyphs - 1.1.7200.16176 - [UserDir] Development Tools - 1.0.6974.21980 - [UserDir] Hyperlink Region - 1.0.7105.20106 - [UserDir] Image Region - 2.99.7100.21996 - [UserDir] Mathcad File Access Functions - 1.0.6983.32721 - [UserDir] MaximaPlugin - 1.98.7100.23756 - [UserDir] Nonlinear Solvers - 1.1.7097.23301 - [UserDir] ODE Solvers - 0.2.7155.3312 - [UserDir] ODE Solvers - 0.2.7155.3312 - [UserDir] PDF Files Plugin - 1.0.7097.27694 - [UserDir] Slider Region - 1.0.7100.22009 - [UserDir] Snapshot Region - 1.0.7100.22017 - [UserDir] Statistical Tools - 1.0.6824.32561 - [UserDir] Writer Region - 0.22.7200.15900 - [UserDir] XlsxImportExport - 1.3.6996.39330 - [UserDir] X-Y Plot Region (JXCharts) - 0.2.7198.38915 - [UserDir] X-Y Plot Region (JXCharts) - 0.2.7198.38915
Updated and rebuilded for SMath Studio ≥ 0.99.7109. |
on 01/11/2019(UTC), on 02/11/2019(UTC)
Joined: 10/12/2009(UTC) Posts: 249 Location: Cali, Colombia Was thanked: 87 time(s) in 66 post(s)
Hi, I found that the following functions of this plugin are not working:
Play(), WRITEWAV(), GETWAVINFO(), READWAV().
I saw the problem inside the interactive SMath Handbook.
I have SMath Studio 0.99.7822 (01 June 2021) on win10.
Oscar
1 user thanked oscampo for this useful post.
Plugin updated. Please try. Changes: - plug-in corrected to respect latest SMath Studio API changes. Edited by user 29 June 2021 15:51:38(UTC)
on 29/06/2021(UTC), on 29/06/2021(UTC)
