SMath Studio Forum
Questions
how to know the name of the variable
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,495 Was thanked: 1275 time(s) in 746 post(s)
Вот так можно решить задачу при помощи компонента Скрипт. Code:var defs = Enumerable.Range( 0, store.Count ).Select( n => store[n] ).ToList();
var args = ( Entry.Create( terms ) ).Items.ToList();
var vars = args.Take(4).Select( x => new Entry( "\"" + x.Text + "\"" ) ).ToList();
var vals = args.Take(4).ToList();
var desc = args.Take(4)
.Select( x => defs.Find( d => d.Name.Equals( x.Text ) ).Description )
.Select( x => new Entry( "\"" + x + "\"" ) ).ToList();
var rows = new Entry( "4" );
var cols = new Entry( "3" );
var mat = new Entry( "mat", TermType.Function, new Entry[]
vars[0], vals[0], desc[0],
vars[1], vals[1], desc[1],
vars[2], vals[2], desc[2],
vars[3], vals[3], desc[3],
rows, cols
store.AddDefinition( args[4].Text, new Term[0], mat );
Script. Kross example 1.sm (7kb) downloaded 14 time(s). Script. Kross example 1.pdf (19kb) downloaded 16 time(s). |
Is there access to some list of definitions in the sheet? The script example seems to reqire explicit specification, which variables are to be processed. Could I just ask to export everything (excluding pre-defined names)? If specification of the variables is acceptable, then the matrix can be created relying on math regions only. export.sm (7kb) downloaded 13 time(s). |
Originally Posted by: mkraska Is there access to some list of definitions in the sheet? The script example seems to reqire explicit specification, which variables are to be processed. Could I just ask to export everything (excluding pre-defined names)? Yes, the first line do it. Code:var defs = Enumerable.Range( 0, store.Count ).Select( n => store[n] ).ToList();
This means: get all enabled definitions. How to check this. Code:var defs = Enumerable.Range( 0, store.Count )
.ToList();
defs.ForEach( d => store.TraceData( d.ToString() ) );
I just downloaded the script region and pasted the code above into it and set language to C#.
This gives the error message in the output window:
Die Datei oder Assembly "LinqBridge, Version=1.3.0.0, Culture=neutral, PublicKeyToken=c2b14eb747628076" oder eine Abhängigkeit davon wurde nicht gefunden. Das System kann die angegebene Datei nicht finden.
(system can't find the file)
SMath Studio: SMath Studio Desktop 0.98.6179.21440, portable, x86 OS: Microsoft Windows NT 6.1.7601 Service Pack 1 (Windows 7 Professional , x64) Screen: 1920x1080 px, 96x96 dpi Localization: separator=<semicolon>; decimal symbol=<comma>; system decimal symbol=<comma>; language=GER Frameworks: CLR 2.0.50727.5485
installed versions: v2.0.50727 2.0.50727.5420 SP2 v3.0 3.0.30729.5420 SP2 v3.5 3.5.30729.5420 SP1 v4 Client 4.6.01055 Full 4.6.01055 v4.0 Client 4.0.0.0 |
Try to remove it manually and update again (20ad815b-bc5e-487d-9258-57fde2ac6de8). For 0.98.6179 last version is 0.1.6273.2204. Edited by user 05 March 2017 20:48:13(UTC)
I deleted the dir and re-installed from extension manager (I did this just some hours ago, thus if the online gallery didn't change, then this didn't change anything locally).
There is a file LinqBridge.dll, yet the log file says
05.03.2017 19:30:58 [INFO ] Script Region, version 0.1.6273.2204, Sonntag, 5. März 2017 01:13:28 05.03.2017 19:31:28 [ERROR] Die Datei oder Assembly "LinqBridge, Version=1.3.0.0, Culture=neutral, PublicKeyToken=c2b14eb747628076" oder eine Abhängigkeit davon wurde nicht gefunden. Das System kann die angegebene Datei nicht finden.
It says that LinqBridge or a dependence of it was not found.
Same message in the output window.
I think I found the problem. Plugin updated, please try again. |
Sorry, didn't solve the problem. This is what the log says:
05.03.2017 20:05:57 [INFO ] Script Region, version 0.1.6273.19487, Sonntag, 5. März 2017 10:49:34 05.03.2017 20:06:20 [ERROR] Die Datei oder Assembly "LinqBridge, Version=1.3.0.0, Culture=neutral, PublicKeyToken=c2b14eb747628076" oder eine Abhängigkeit davon wurde nicht gefunden. Das System kann die angegebene Datei nicht finden.
I forgot to replace Tech.CodeGeneration.dll. Plugin updated, try again. Edited by user 05 March 2017 22:24:19(UTC)
05.03.2017 20:31:31 [INFO ] Script Region, version 0.1.6273.20457, Sonntag, 5. März 2017 11:21:54 05.03.2017 20:31:54 [ERROR] Die Datei oder Assembly "LinqBridge, Version=1.3.0.0, Culture=neutral, PublicKeyToken=c2b14eb747628076" oder eine Abhängigkeit davon wurde nicht gefunden. Das System kann die angegebene Datei nicht finden.
Originally Posted by: mkraska 05.03.2017 20:31:31 [INFO ] Script Region, version 0.1.6273.20457, Sonntag, 5. März 2017 11:21:54 05.03.2017 20:31:54 [ERROR] Die Datei oder Assembly "LinqBridge, Version=1.3.0.0, Culture=neutral, PublicKeyToken=c2b14eb747628076" oder eine Abhängigkeit davon wurde nicht gefunden. Das System kann die angegebene Datei nicht finden.
Only portable version not working or both? |
Originally Posted by: uni Only portable version not working or both?
Good point, installer version works. But installer version is a bad place for experiments. |
Ok, I need portable version. How I can get it? This link not working for me. |
Currently the link is broken. Unpacking the linux version to some directory and placing an empty file "portable.version" in the install dir is a workaround (or better: the official way). |
Well, I reproduced the problem. It is much harder to fix than I thought before (I don't know why it is happening for portable version). |
Something close to your request (input must be provided with strings, output is automated and issues reported in trace window) name+value+description.sm (8kb) downloaded 24 time(s).Edited by user 17 March 2017 18:51:23(UTC)
SMath Studio Forum
Questions
