Offline frapuano
#1 Posted : 21 February 2017 23:58:54(UTC)
frapuano
Was thanked: 13 time(s) in 13 post(s)
Hi Martin,
this is just to know if it is possible from Smath using Maxima to handle limits of functions of 2 variables.
Thanks in advance for your feedback
Franco
Offline mkraska
#2 Posted : 22 February 2017 00:39:02(UTC)
mkraska
Was thanked: 1127 time(s) in 723 post(s)
There is no hint on such capabilities in the maxima handbook.
#3 Posted : 22 February 2017 19:11:28(UTC)
The limit of a function of two variables is the contour limit @ user value.
Maxima X_Y plots by default the 0 level contour. For other 'level(s)'
use the maple solve block.
Offline mkraska
#4 Posted : 22 February 2017 20:08:40(UTC)
mkraska
What is a Maxima X_Y plot? Why would you need some solver for other levels if you can plot 0 level?
As I understand, the bivariate limit is a function of the x,y values and of the direction of approach.
It would be helpful to see what you expect to see (examples).
#5 Posted : 23 February 2017 19:41:09(UTC)
What is the meaning of: handle limits of functions of 2 variables
Wait for the f(x,y):=
X_Y plots contour of any level in the domain of existence w/o solver.
The solver is for discretising the export.
Contour [Wolfram Looping].sm (20kb) downloaded 28 time(s).
Offline frapuano
#6 Posted : 24 February 2017 11:15:10(UTC)
frapuano
Joan unlukily doesn't work this way.
For a limit of a function in 2 variables ( or more ) its results may depends on the path used to reach it so the program I guess that needs to use a coordinate conversion or other methods to find it and to check that is independent from the path used .
So it is necessary a specific algorithmic "intelligence" to solve such a type of problems.
In my search have found a Wolfram alpha widget that does this in a very good way ...
http://www.wolframalpha....16861a528d6221f5ac88eefd
Franco
#7 Posted : 24 February 2017 21:11:27(UTC)
Wolfram is of no help as you can check by yourself: it is ill posed.
"the limit of functions of two variables ..."
read: implict f(x,y) have solutions wrt 'x' or 'y' alternately.
Read the two Smath documents
Forum Implicit Limit.sm (13kb) downloaded 21 time(s).
Forum Implicit Wolfram.sm (5kb) downloaded 17 time(s).
#8 Posted : 24 February 2017 21:26:01(UTC)
From the previous work sheets, answer is probably "NO"
Maxima will plot many implicit functions.
In the attached:
1. Valery Ochov "ImplicitFunctionGrapher"
2. an example of the CONTOUR matrix extractor
I presume I can exemplify the 'maple' RootOf,
Please, let me know.
Contour ImplicitFunctionGrapher.sm (29kb) downloaded 25 time(s).
Contour Advisor [Publish].sm (27kb) downloaded 22 time(s).
