Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,495 Was thanked: 1275 time(s) in 746 post(s)
Updated. The problem was in the handling of Greek characters. I hope I did not break anything. Edited by user 02 December 2016 21:54:18(UTC)
on 02/12/2016(UTC), on 03/12/2016(UTC)
Updated for two last stable releases. It is about greek names again. There is a problem with ; as argument separator. I don't know how to solve this now. |
Simple example with using greek identifiers. |
5 users thanked uni for this useful post.
on 09/12/2016(UTC), on 09/12/2016(UTC), on 10/12/2016(UTC), on 10/12/2016(UTC), on 10/12/2016(UTC)
Joined: 01/08/2010(UTC) Posts: 115 Location: Rome Was thanked: 13 time(s) in 13 post(s)
Hi Uni,
as far as you know is it possible to solve inequalities with the Maple Wrapper ?
Franco
Originally Posted by: frapuano as far as you know is it possible to solve inequalities with the Maple Wrapper ?
Franco, Did you mean "equalities" ? rather than than "INequalities" maple(dsolve) from Viacheslav is OK but not mathematically correct. Jean
Smath 5346 does not take capital Greek: ... no big deal... in the red: maple takes φ but rejects Φ ODE Maple MORE.sm (61kb) downloaded 53 time(s).
... for those Collabs reading this thread, observe: in Maple dsolve: _C1, _C2 are not re-addressable. Why ? => the solution is not an explicit function ! just a plot canvas solution ... gorgeous Smath !!! Similar instances _Z appear in the result "RootOf" in this case, _Z is re-addressable by reconstruction. In the "invlaplace", multiple "RootOf" solve by the maple "allvalues". Thanks Viacheslav for the dsolve demo.
... I was wrong in my previous thread:
I am talking of inequalities i.e solve with the Maple Wrapper an expression like X^2+3*X+4>0.
Franco
Originally Posted by: frapuano Jean
I am talking of inequalities i.e solve with the Maple Wrapper an expression like X^2 3*X 4 OK Franco: Then post your work sheet.
Updated. Maple region implemented. Only ans variable available outside region. maple.sm (10kb) downloaded 66 time(s). maple.pdf (40kb) downloaded 52 time(s).Edited by user 06 July 2018 19:24:04(UTC)
6 users thanked uni for this useful post.
on 06/07/2018(UTC), on 06/07/2018(UTC), on 06/07/2018(UTC), on 06/07/2018(UTC), on 07/07/2018(UTC), on 16/08/2018(UTC)
Updated. Added support for [CTRL]+[SHIFT]+K. |
Originally Posted by: uni Updated. Added support for [CTRL] [SHIFT] K. In that new code, something does not cut the mustard !
Originally Posted by: Jean Giraud In that new code, something does not cut the mustard ! ... here is the answer:
Joined: 28/08/2014(UTC) Posts: 1,368 Was thanked: 829 time(s) in 525 post(s)
Hi Uni. Thanks a lot for this update. How can access to SMath variables? Seems that isn't with `::fun` Best regards. Alvaro. Edited by user 16 August 2018 14:30:14(UTC)
Originally Posted by: Razonar How can access to SMath variables? Seems that isn't with `::fun`
Alvaro. You assign the Maple solution to a user function defined wrt the Maple variable you have solve for. Here, Maple is solving Laplace wrt 't', thus sol(t). Maple stacks multiple solutions. Not sure if I understand your question clearly. Jean
Hi Jean. I'm talking about this feature: Originally Posted by: uni Updated. This is an experimental thing for scripting support. Best regards. Alvaro.
Originally Posted by: Razonar How can access to SMath variables? Seems that isn't with `::fun` I changed the code and this feature was removed. I'll see how it can be restored. |
