Offline ndtma
#1 Posted : 12 October 2016 14:09:25(UTC)
ndtma
Sri Lanka
Was thanked: 125 time(s) in 82 post(s)
Unable to install Text Region Utilities plugin in 98.6128
thanks 1 user thanked ndtma for this useful post.
on 12/10/2016(UTC)
#2 Posted : 12 October 2016 16:35:31(UTC)
Was thanked: 1334 time(s) in 877 post(s)
thank you, I'll fix it ASAP Good
Offline Andrey Ivashov
#3 Posted : 12 October 2016 17:39:21(UTC)
Davide, I've already fixed it by simple plug-in rebuild. Sorry, had no chance to inform you.
New version of the plug-in can be installed with no issues.
on 12/10/2016(UTC)
Offline ndtma
#4 Posted : 12 October 2016 18:12:15(UTC)
ndtma
Sri Lanka
Thank you Andrey and Davide for the fix.
Offline ndtma
#5 Posted : 13 October 2016 06:45:45(UTC)
ndtma
Sri Lanka
The "insert a toolbox" in Text Region Utilities Plug-in exibit erratic behaviour.
1. It shifts the selected text to a new position.
2. Apparantly, the empty lines between text lines are also considered as text?
3. Had to press "Apply" more than once to convert all selected text.
Edited by user 13 October 2016 06:47:47(UTC)  | Reason: Not specified
#6 Posted : 13 October 2016 11:55:24(UTC)
Thank you NDTM,
Fixing it, there were some changes in the API.
I'm not able to reproduce it; if you save the document with text regions and you load it again it still happens? If yes can you attach it here?
Edited by user 13 October 2016 13:39:01(UTC)  | Reason: Not specified
#7 Posted : 13 October 2016 16:24:20(UTC)
I don't understand what a "Tool Box" could be ?
Smath 5346 "Text Box" allows lot of decoration.
Decoration for a Web page presentation for instance.
As an Engineering working document: decoration is
too much, IMHO.
Each Shift/Enter adds blank line(s), an empty space
where to slide: images, graphs, foreign text ...
Offline ndtma
#8 Posted : 13 October 2016 16:52:19(UTC)
ndtma
Sri Lanka
Thank you Davide!
The original file is attached; the problem still exists even after saving and re-opening.
Before Text Converter.sm (74kb) downloaded 45 time(s).
on 13/10/2016(UTC)
#9 Posted : 13 October 2016 17:23:02(UTC)
Thank you, is exactly what I was thinking. If you select all (CTRL+A) you can see some empty text region, probably created with an UNDO action (because my bad coding in the converter feature). Should be no more an issue with the coming plugin update (but if existing you have to remove them manually).
I don't understand what a "Tool Box" could be?
Just a region that wraps some generic utilities related to the worksheet; when it will be possible I plan to move them in a toolbar (I'm working on it).
Edited by user 13 October 2016 17:26:00(UTC)  | Reason: Not specified
#10 Posted : 13 October 2016 19:56:56(UTC)
PLUGIN UPDATED Beta
SMath Studio 0.98.6128
  • fixed issues related to API changes;
  • Text to Writer converter: history UNDO action managed correctly;
  • Text to Writer converter: fixed hyperlink conversion;
  • Batch hyperlinks: it is now possible to choose a path to investigate before launching the scan;
Edited by user 13 October 2016 21:01:03(UTC)  | Reason: last-minute fix
on 13/10/2016(UTC)
Offline ndtma
#11 Posted : 13 October 2016 20:40:46(UTC)
ndtma
Sri Lanka
Thank you Davide for the update.
on 13/10/2016(UTC)
Offline Alex M.
#12 Posted : 15 December 2016 20:43:38(UTC)
Alex M.
Plugin does not seem to work in latest SS 6179
#13 Posted : 15 December 2016 21:22:31(UTC)
Thank you Alex,
recompiled, try now.
on 16/12/2016(UTC)
Offline Alex M.
#14 Posted : 16 December 2016 21:34:02(UTC)
Alex M.
works fine now, thanks!
Guest (3)
