Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
Unable to install Text Region Utilities plugin in 98.6128 |
1 user thanked ndtma for this useful post.
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,649 Location: Italy Was thanked: 1333 time(s) in 877 post(s)
thank you, I'll fix it ASAP |
Davide, I've already fixed it by simple plug-in rebuild. Sorry, had no chance to inform you.
New version of the plug-in can be installed with no issues.
Thank you Andrey and Davide for the fix. |
The "insert a toolbox" in Text Region Utilities Plug-in exibit erratic behaviour. 1. It shifts the selected text to a new position. 2. Apparantly, the empty lines between text lines are also considered as text? 3. Had to press "Apply" more than once to convert all selected text. Edited by user 13 October 2016 06:47:47(UTC)
Thank you NDTM, Originally Posted by: ndtma 1. It shifts the selected text to a new position. 3. Had to press "Apply" more than once to convert all selected text. Fixing it, there were some changes in the API. Originally Posted by: ndtma 2. Apparantly, the empty lines between text lines are also considered as text? I'm not able to reproduce it; if you save the document with text regions and you load it again it still happens? If yes can you attach it here? Edited by user 13 October 2016 13:39:01(UTC)
I don't understand what a "Tool Box" could be ? Smath 5346 "Text Box" allows lot of decoration. Decoration for a Web page presentation for instance. As an Engineering working document: decoration is too much, IMHO. Each Shift/Enter adds blank line(s), an empty space where to slide: images, graphs, foreign text ...
Thank you Davide! The original file is attached; the problem still exists even after saving and re-opening. Before Text Converter.sm (74kb) downloaded 45 time(s). |
Originally Posted by: ndtma the problem still exists even after saving and re-opening. Thank you, is exactly what I was thinking. If you select all (CTRL+A) you can see some empty text region, probably created with an UNDO action (because my bad coding in the converter feature). Should be no more an issue with the coming plugin update (but if existing you have to remove them manually). Originally Posted by: Jean Giraud I don't understand what a "Tool Box" could be? Just a region that wraps some generic utilities related to the worksheet; when it will be possible I plan to move them in a toolbar (I'm working on it). Edited by user 13 October 2016 17:26:00(UTC)
PLUGIN UPDATED SMath Studio 0.98.6128- fixed issues related to API changes;
- Text to Writer converter: history UNDO action managed correctly;
- Text to Writer converter: fixed hyperlink conversion;
- Batch hyperlinks: it is now possible to choose a path to investigate before launching the scan;
Edited by user 13 October 2016 21:01:03(UTC)
| Reason: last-minute fix |
Thank you Davide for the update. |
Plugin does not seem to work in latest SS 6179
Thank you Alex,
recompiled, try now. |
