2 Pages12>
Offline Khram
#1 Posted : 05 April 2016 13:25:16(UTC)
Khram
Пожалуйста поправьте ошибку, появившуюся после версии 097-5890
Edited by moderator 15 September 2016 17:32:47(UTC)  | Reason: marked as fixed
Offline mikekaganski
#2 Posted : 05 April 2016 14:24:49(UTC)
mikekaganski
Was thanked: 151 time(s) in 107 post(s)
ЧЯДНТ? Good
Actually, I see another strange thing, that nevertheless, doesn't change results: If I show result immediately on assignment, following derivative optimizes differently.
Best regards,
Mike Kaganski
thanks 1 user thanked mikekaganski for this useful post.
on 09/04/2016(UTC)
Offline Alex M.
#3 Posted : 05 April 2016 18:07:16(UTC)
Alex M.
Прикрепи .SM файл с ошибкой к сообщению... Видишь, у Михаила все работает и сложно разобраться что к чему (то есть в проге ли ошибка или в твоем документе)
#4 Posted : 05 April 2016 18:23:32(UTC)
Offline CBG
#5 Posted : 06 April 2016 06:58:56(UTC)
CBG
In the new version of Smath Studio ( 0.98 5935 ) , the "diff" function does not work properly, and gives the following error : diff () function is not defined.
#6 Posted : 06 April 2016 07:04:15(UTC)
mikekaganski
Could you guys please check if a plugin causes that? Does disabling plugins solve the problem?
Best regards,
Mike Kaganski
Offline CBG
#7 Posted : 06 April 2016 07:29:08(UTC)
CBG
This worked very well with the previous version of Studio Smath with the same plugins that I have installed.
#8 Posted : 06 April 2016 07:43:59(UTC)
mikekaganski
The question isn't in if it worked before. The question is, if this is some plugin, then its maintainer should update it, because it apparently is broken. Bare SMath's diff works well (at least in some installations, e.g. mine, with English locale). So, could you check if you can fix the problem turning off some plugin, and if yes, then which plugin is that?
Best regards,
Mike Kaganski
#9 Posted : 06 April 2016 07:59:26(UTC)
Maxima diff takes scalar fuction. You are feeding a vector.
diff("1:expression", "2:expression"Wink -
[built-in] or [Maxima] derivate(expr, var) derivates expr
with respect to var. diff((1+x+x^2+y),x) => 1+2*x
It could be the previous new version included a new derivative
operator, something like Mathcad .
#10 Posted : 06 April 2016 08:16:34(UTC)
Smath Studio with the same plugins that I have installed.
Try other style 'diff'
Forum Legendre Test.sm (9kb) downloaded 51 time(s).
Offline Ber7
#11 Posted : 06 April 2016 18:40:43(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
I confirm. I already wrote about it
http://en.smath.info/forum/yaf_...he-numerical-result.aspx
My animation programs do not work in Smath 0.98 5935 , as Smath 0.98 5935 does not recognize the coding of the Jacobi
matrix.
http://en.smath.info/forum/yaf_...-spatial-mechanisms.aspx
http://en.smath.info/forum/yaf_...-degrees-of-freedom.aspx
Edited by user 06 April 2016 19:43:31(UTC)  | Reason: Not specified
thanks 1 user thanked Ber7 for this useful post.
on 10/05/2016(UTC)
Offline CBG
#12 Posted : 06 April 2016 18:49:09(UTC)
CBG
Jeand Giraud:
Your "Forum Legendre Test.sm", file does not work correctly in the current version of SMath Studio that I have installed.
Offline CBG
#13 Posted : 06 April 2016 19:01:12(UTC)
CBG
mikekaganki : I disable all plugins, and the problem persists .
It seems to be a bug in the new version
Offline ndtma
#14 Posted : 06 April 2016 19:03:46(UTC)
ndtma
Rank:: Advanced Member
Sri Lanka
Was thanked: 127 time(s) in 82 post(s)
It works for me in SS 98.5935.
#15 Posted : 06 April 2016 19:04:08(UTC)
Thanks "CBG" for reporting. In Smath 5346 it does not go further than order 5,
it might ... but next century ! I was wise to tabulate "wr" the wi & roots.
So you can experiment. I have it otherwise from Mathcad but Smath does not
directly extract the coefficients for polyroots. If you are interested, in
that stuff, please let me know and see how we can collaborate.
I you read my just posted message "Install Smath 5935"
can you why I shit in my pants
Cheers, Jean
#16 Posted : 06 April 2016 19:40:40(UTC)
Thanks "ndtma" for checking.
Does that mean the chiken is still live in the pot ?
#17 Posted : 06 April 2016 19:50:51(UTC)
I'm sure Smath 5935 is a working version in the creators machine.
But another story on users machine. Thus the need to proper intructions
how to uninstall previous, install new. Not so simple from Mathcad 11 that
made new 11 owners go crazy. A strict rigid procedure was not given.
Offline ndtma
#18 Posted : 06 April 2016 19:51:27(UTC)
ndtma
Sri Lanka
Hi Jean,
Thanks.
The culprit is the Maxima plugin. We have to delete this plug in to get your program to run correctly.
If the plugin is disabled and then re-calculated, the program will run correct.
However, disabling is not effective, as the error will re-appear when the program is reloaded.
The error is reproduced below.
Edited by user 06 April 2016 20:09:41(UTC)  | Reason: Not specified
thanks 3 users thanked ndtma for this useful post.
on 06/04/2016(UTC),  on 06/04/2016(UTC),  on 06/04/2016(UTC)
Offline CBG
#19 Posted : 06 April 2016 20:12:25(UTC)
CBG
I found the fault, this is caused by the Maxima Plugin.
I Disable it , and Smath Studio works perfectly .
Mikekaganki was right .
Thanks and regards
to all
CBG
thanks 1 user thanked CBG for this useful post.
on 06/04/2016(UTC)
Offline Khram
#20 Posted : 08 April 2016 17:42:48(UTC)
Khram
SMath заново переустановил, с нуля, однако чуда не случилось. Очень печально. ОС - Windows-10/64 на AMD A8-4555 APU with Radeon
Dipole-3.sm (40kb) downloaded 38 time(s).
2 Pages12>
