SMath Studio Forum
Bugs & Problems
[SS-2311][MAXIMA] Why doesn't work in 0.98?
Joined: 11/03/2016(UTC) Posts: 3   Location: Sakhalin
Пожалуйста поправьте ошибку, появившуюся после версии 097-5890  Edited by moderator 8 years ago
| Reason: marked as fixed
Joined: 17/01/2013(UTC) Posts: 296   Location: Khabarovsk, Russia Was thanked: 151 time(s) in 107 post(s)
Originally Posted by: Khram  Пожалуйста поправьте ошибку, появившуюся после версии 097-5890  ЧЯДНТ?  Actually, I see another strange thing, that nevertheless, doesn't change results: If I show result immediately on assignment, following derivative optimizes differently.  |
Best regards, Mike Kaganski |
 1 user thanked mikekaganski for this useful post.
Joined: 03/03/2014(UTC) Posts: 418  Was thanked: 127 time(s) in 96 post(s)
Прикрепи .SM файл с ошибкой к сообщению... Видишь, у Михаила все работает и сложно разобраться что к чему (то есть в проге ли ошибка или в твоем документе)
Joined: 04/07/2015(UTC) Posts: 6,866  Was thanked: 983 time(s) in 811 post(s)
In the new version of Smath Studio ( 0.98 5935 ) , the "diff" function does not work properly, and gives the following error : diff () function is not defined.
Originally Posted by: CBG  In the new version of Smath Studio ( 0.98 5935 ) , the "diff" function does not work properly, and gives the following error : diff () function is not defined.
Originally Posted by: Khram  Пожалуйста поправьте ошибку, появившуюся после версии 097-5890 Could you guys please check if a plugin causes that? Does disabling plugins solve the problem? |
 This worked very well with the previous version of Studio Smath with the same plugins that I have installed.
The question isn't in if it worked before. The question is, if this is some plugin, then its maintainer should update it, because it apparently is broken. Bare SMath's diff works well (at least in some installations, e.g. mine, with English locale). So, could you check if you can fix the problem turning off some plugin, and if yes, then which plugin is that? |
Maxima diff takes scalar fuction. You are feeding a vector. diff("1:expression", "2:expression"  - [built-in] or [Maxima] derivate(expr, var) derivates expr with respect to var. diff((1+x+x^2+y),x) => 1+2*x It could be the previous new version included a new derivative operator, something like Mathcad . Jean
Originally Posted by: CBG  This worked very well with the previous version of Smath Studio with the same plugins that I have installed. Try other style 'diff' Forum Legendre Test.sm (9kb) downloaded 52 time(s).
Joined: 15/07/2010(UTC) Posts: 437   Location: Beer-Sheva Was thanked: 520 time(s) in 288 post(s)
 1 user thanked Ber7 for this useful post.
Jeand Giraud: Your "Forum Legendre Test.sm", file does not work correctly in the current version of SMath Studio that I have installed.
mikekaganki : I disable all plugins, and the problem persists . It seems to be a bug in the new version
Joined: 05/06/2014(UTC) Posts: 350   Location: Colombo Was thanked: 129 time(s) in 83 post(s)
Hi, It works for me in SS 98.5935.  |
Originally Posted by: CBG  Your "Forum Legendre Test.sm", file does not work correctly in the current version of SMath Studio that I have installed. Thanks "CBG" for reporting. In Smath 5346 it does not go further than order 5, it might ... but next century ! I was wise to tabulate "wr" the wi & roots. So you can experiment. I have it otherwise from Mathcad but Smath does not directly extract the coefficients for polyroots. If you are interested, in that stuff, please let me know and see how we can collaborate. I you read my just posted message "Install Smath 5935" can you why I shit in my pants Cheers, Jean
Thanks "ndtma" for checking. Does that mean the chiken is still live in the pot ?
I'm sure Smath 5935 is a working version in the creators machine. But another story on users machine. Thus the need to proper intructions how to uninstall previous, install new. Not so simple from Mathcad 11 that made new 11 owners go crazy. A strict rigid procedure was not given.
Hi Jean, Thanks. The culprit is the Maxima plugin. We have to delete this plug in to get your program to run correctly. If the plugin is disabled and then re-calculated, the program will run correct. However, disabling is not effective, as the error will re-appear when the program is reloaded. The error is reproduced below.  Edited by user 9 years ago
 3 users thanked ndtma for this useful post.
on 06/04/2016(UTC), on 06/04/2016(UTC), on 06/04/2016(UTC)
I found the fault, this is caused by the Maxima Plugin. I Disable it , and Smath Studio works perfectly . Mikekaganki was right . Thanks and regards to all CBG Falla_diff_3.png (851kb) downloaded 40 time(s).
 1 user thanked CBG for this useful post.
SMath заново переустановил, с нуля, однако чуда не случилось. Очень печально. ОС - Windows-10/64 на AMD A8-4555 APU with Radeon  Dipole-3.sm (40kb) downloaded 39 time(s).
SMath Studio Forum
Bugs & Problems
