Joined: 22/10/2009(UTC) Posts: 53 Location: Gedongkuning, Jogjakarta Was thanked: 1 time(s) in 1 post(s)
Hello waluyo,
You have a singular point at the lower limit (0) - (division by zero). In SMath there is a simple Simpson based integration formula implemented at the moment. The best you can get is to use some small number instead of zero (although the result will be erronous). I hope that some more sophisticated numerical (maybe analytical as well) integration algorithms will be implemented in SMath sooner or later.
Regards, Radovan |
