SMath Studio Forum
Bugs & Problems
Integration problem with user defined function with units in Latest SS 0.99.6877
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 127 time(s) in 82 post(s)
Thank you Andrey for the latest SS 0.99.6877. However, I observe a problem in integrating a user defined function with units. The attached SS document (and all similar docs) worked fine in all previous SS versions without any issue. Malwala Reservoir Flood Capacity Estimation-Simple.sm (250kb) downloaded 17 time(s).Edited by moderator 07 November 2018 12:22:56(UTC)
| Reason: fixed in SMath Studio 0.99.6884 |
1 user thanked ndtma for this useful post.
Thank you! For some reason I had no automated test with such example (integral with units) and that is why I didn't catch this error before the latest beta release. Will add example to tests and make a fix asap. Thanks for the report!
on 31/10/2018(UTC), on 05/11/2018(UTC)
Thank you Andrey for the fix. |
SMath Studio Forum
Bugs & Problems
