How do I compare two formulas?
Like, if I simplify by hand, or solve for x by hand - and I'd like to check if I did it correctly. What I want to compare, are two equations...
For example: y = ax + b
And then compare to: x = (y - b ) / a
And have it reply with "True".
As compared to if I wrote x = (- y - b ) / - a
  Rank: Administration Groups: Registered, Administrators, Advanced Member Joined: 23/06/2009(UTC) Posts: 1,735   Was thanked: 313 time(s) in 267 post(s)
Helo Mike, At the moment, for this kind of problem you have to use some CAS (Maxima maybe?) Code:
Solve over x
>:: sol1:=solve(y=a*x+b,x)
y - b
[x = -----]
a
Solved by hand
>:: sol2:=(-y-b)/a
- y - b
a
Compared
>:: if(at(x,sol1)=sol2) then "true" else "false"
false
Compared
>:: if(at(x,sol1)=(y-b)/a) then "true" else "false"
true
Regards, Radovan Edited by user 03 May 2010 13:04:02(UTC)
Ah, so it is not possible :P Thanks for reply
  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,472   Was thanked: 1735 time(s) in 587 post(s)
Hello, I was thinking in this direction, but unfortunately this is not so simple. Please see the examples. Wrong answer "true", it should be "false":  Neither "true" nor "false". If statement needs the numerical result of the logical contidion.  Regards, Radovan |
Hello Andrey, Yes, I think you are right  . We were thinking on the same thing at this very moment. Regards, Radovan |
