Offline LordMike
#1 Posted : 01 May 2010 20:17:48(UTC)
LordMike
How do I compare two formulas?
Like, if I simplify by hand, or solve for x by hand - and I'd like to check if I did it correctly.
What I want to compare, are two equations...
For example:
y = ax + b
And then compare to:
x = (y - b ) / a
And have it reply with "True".
As compared to if I wrote x = (- y - b ) / - a
Offline omorr
#2 Posted : 03 May 2010 05:32:23(UTC)
omorr
Serbia
Helo Mike,
At the moment, for this kind of problem you have to use some CAS (Maxima maybe?)
Code:
 Solve over x
>:: sol1:=solve(y=a*x+b,x)
                                        y - b
                                   [x = -----]
                                          a
 Solved by hand
>:: sol2:=(-y-b)/a
                                     - y - b
                                        a
 Compared
>:: if(at(x,sol1)=sol2) then "true" else "false"
                                      false
 Compared
>:: if(at(x,sol1)=(y-b)/a) then "true" else "false"
                                      true
Edited by user 03 May 2010 13:04:02(UTC)  | Reason: Not specified
Offline LordMike
#3 Posted : 05 May 2010 04:35:18(UTC)
LordMike
Ah, so it is not possible :P
Thanks for reply Wink
Offline Andrey Ivashov
#4 Posted : 09 May 2010 02:05:03(UTC)
Why? Acute
(download source file)
Offline omorr
#5 Posted : 09 May 2010 03:12:22(UTC)
omorr
Serbia
I was thinking in this direction, but unfortunately this is not so simple. Please see the examples.
Wrong answer "true", it should be "false":
Neither "true" nor "false". If statement needs the numerical result of the logical contidion.
#6 Posted : 09 May 2010 03:35:01(UTC)
Ok, then we can use this stuff:
Regards.
Offline omorr
#7 Posted : 09 May 2010 03:58:28(UTC)
omorr
Serbia
Hello Andrey,
Yes, I think you are right Good . We were thinking on the same thing at this very moment.
