Offline maweilian
#1 Posted : 25 March 2010 19:51:39(UTC)
maweilian
Was thanked: 5 time(s) in 5 post(s)
I am using version 0.87.3728. I performed the calculation below:
As you can see the answer should be simply -0.4063804, but Smath added an unwarranted, very small imaginary number to the answer.
Will Massie
Mechanical Engineer
Oregon, USA
Offline omorr
#2 Posted : 25 March 2010 23:49:31(UTC)
omorr
Serbia
Hello Will,
I tried this on 0.87 stable (0.87.3692)
Could you double check it. This looks to me Ok, although quite different from your result.
I again forgot to bring 0.87 Beta with me, sorry. I'll check this out tomorow.
Offline maweilian
#3 Posted : 26 March 2010 02:01:50(UTC)
maweilian
omorr wrote:
Hello Will,
I downloaded and installed the stable version (0.87) and it also worked fine for me.
So this must be a bug in 0.87 Beta.
Thanks for the help.
Will Massie
Mechanical Engineer
Oregon, USA
Offline omorr
#4 Posted : 26 March 2010 03:19:50(UTC)
omorr
Serbia
You are welcome Good ,
You might be right. I mentioned some odd behavior wnen using trigonometric fuctions with units arguments in the first Beta. Andrey fixed that. It might remain some unfinished work on the same issue.
Offline omorr
#5 Posted : 26 March 2010 13:24:13(UTC)
omorr
Serbia
Hello Will,
Here is the 0.87_3728 version of your example made on my computer.
It is again different than yours but closer to mine previously made on 0.87 Stable.
I think that the imaginary part could be freely neglected here (less than 10^(-15). If the SMath would have had the system of representing results with the given precision, this imaginary part would have not been presented here. Therefore, I suggest you to use just the real part of the results.
On the other hand I am not sure why our results are so different?
Edited by user 26 March 2010 13:26:55(UTC)  | Reason: Not specified
Offline captainblack
#6 Posted : 26 March 2010 21:46:04(UTC)
captainblack
Rank: Member
maweilian wrote:
omorr wrote:
Hello Will,
Note that you had the angle mode set to degrees and omorr has his set to radians (0.87 seems to return a real result in either mode)
CB
Offline omorr
#7 Posted : 26 March 2010 22:21:19(UTC)
omorr
Serbia
Oh yes, thank you captainblack. I just forgot to check that out Blush . It did not come to my mind, sorry.
Edited by user 26 March 2010 22:23:27(UTC)  | Reason: Not specified
Offline maweilian
#8 Posted : 29 March 2010 22:26:47(UTC)
maweilian
omorr wrote:
Hello Will,
Radovan,
As CB said, I was performing the calculation in degrees, but, as you have demonstrated, the inclusion of an imaginary component occurs regardless of whether degrees or radians are used. In this case, I did end up using the real component. However, since I use Smath to clearly document calculations, the results produced by Smath in this case are unacceptable since it introduces unnecessary clutter to what should be a straightforward calculation. So, I would most certainly add this problem to the "to be fixed" list for 0.87 Beta.
Sincerely,
Will
Edited by user 29 March 2010 22:28:20(UTC)  | Reason: Not specified
Will Massie
Mechanical Engineer
Oregon, USA
Offline omorr
#9 Posted : 29 March 2010 22:50:04(UTC)
omorr
Serbia
Hello Will,
I suppose that SMath should have Zero and Complex treshold in order to avoid these situations. This way would overcome the mentioned problems.
Offline Andrey Ivashov
#10 Posted : 30 March 2010 01:02:03(UTC)
Agree with you. Will implement this.
