Joined: 09/01/2010(UTC) Posts: 102 Location: Oregon, USA Was thanked: 5 time(s) in 5 post(s)
I am using version 0.87.3728. I performed the calculation below: As you can see the answer should be simply -0.4063804, but Smath added an unwarranted, very small imaginary number to the answer. |
Will Massie Mechanical Engineer Oregon, USA |
Hello Will, I tried this on 0.87 stable (0.87.3692) Could you double check it. This looks to me Ok, although quite different from your result. I again forgot to bring 0.87 Beta with me, sorry. I'll check this out tomorow. Regards, Radovan |
omorr wrote:Hello Will,
Regards, Radovan I downloaded and installed the stable version (0.87) and it also worked fine for me. So this must be a bug in 0.87 Beta. Thanks for the help. |
You are welcome , You might be right. I mentioned some odd behavior wnen using trigonometric fuctions with units arguments in the first Beta. Andrey fixed that. It might remain some unfinished work on the same issue. Regards, Radovan |
Hello Will, Here is the 0.87_3728 version of your example made on my computer. It is again different than yours but closer to mine previously made on 0.87 Stable. I think that the imaginary part could be freely neglected here (less than 10^(-15). If the SMath would have had the system of representing results with the given precision, this imaginary part would have not been presented here. Therefore, I suggest you to use just the real part of the results. On the other hand I am not sure why our results are so different? Regards, Radovan Edited by user 26 March 2010 13:26:55(UTC)
Joined: 29/01/2010(UTC) Posts: 13 Location: Portsmouth UK
maweilian wrote:omorr wrote:Hello Will,
Regards, Radovan I downloaded and installed the stable version (0.87) and it also worked fine for me. So this must be a bug in 0.87 Beta. Thanks for the help. Note that you had the angle mode set to degrees and omorr has his set to radians (0.87 seems to return a real result in either mode) CB
Oh yes, thank you captainblack. I just forgot to check that out . It did not come to my mind, sorry. Regards, Radovan Edited by user 26 March 2010 22:23:27(UTC)
omorr wrote:Hello Will, If the SMath would have had the system of representing results with the given precision, this imaginary part would have not been presented here. Therefore, I suggest you to use just the real part of the results.
Radovan, As CB said, I was performing the calculation in degrees, but, as you have demonstrated, the inclusion of an imaginary component occurs regardless of whether degrees or radians are used. In this case, I did end up using the real component. However, since I use Smath to clearly document calculations, the results produced by Smath in this case are unacceptable since it introduces unnecessary clutter to what should be a straightforward calculation. So, I would most certainly add this problem to the "to be fixed" list for 0.87 Beta. Sincerely, Will Edited by user 29 March 2010 22:28:20(UTC)
Hello Will,
I suppose that SMath should have Zero and Complex treshold in order to avoid these situations. This way would overcome the mentioned problems.
Regards, Radovan |
omorr wrote:I suppose that SMath should have Zero and Complex treshold in order to avoid these situations. This way would overcome the mentioned problems. Agree with you. Will implement this.
