Active Users
#1 Posted : 17 December 2013 03:01:40(UTC)
Hi all,
Here there is a plugin to have currencies and exchange rates in SMath Studio.
Infos:
Functions:
  • SetCurrencyUnits(1), SetCurrencyUnits(2): extends SMath Studio with currency units. When an internet connection is available, exchange rates are kept updated using the ECB reference rates (internet connection not required but useful);
    Quote:
    The reference rates are usually updated by 3 p.m. C.E.T. They are based on a regular daily concertation procedure between central banks across Europe and worldwide, which normally takes place at 2.15 p.m. CET.
  • GetYahooExchangeRate(2): get a wide set of exchange rates from Yahoo Finance (internet connection required); service discontinued by Yahoo
>>> PLEASE REPORT IN THIS TOPIC ANY ISSUE, MORE DETAILED AS POSSIBLE <<<
Edited by user 24 October 2018 02:07:23(UTC)  | Reason: description updated
File Attachment(s):
CurrencyUnits.sm (26kb) downloaded 258 time(s).
thanks 3 users thanked Davide Carpi for this useful post.
on 17/12/2013(UTC),  on 18/12/2013(UTC),  on 18/12/2013(UTC)
Offline mkraska
#2 Posted : 17 December 2013 03:35:09(UTC)
mkraska
Nice work, Davide. However, does not work with , as decimal separator.
#3 Posted : 17 December 2013 04:05:39(UTC)
Thank you Martin, try with the update Good
Offline mkraska
#4 Posted : 17 December 2013 10:23:36(UTC)
mkraska
Better now, but still no connectivity. I guess that is sort of firewall or proxy issue.
Offline omorr
#5 Posted : 17 December 2013 13:00:17(UTC)
omorr
Serbia
Unfortunately Davide, this does not work for me (Win7 x64). Plugin refuses to install properly.
#6 Posted : 17 December 2013 15:07:23(UTC)
ok... as for now the password is: TEST
Try again, I've made some changes... If doesn't work try NetTest(0) and NetTest(1) and post a screenshot Good
Umnik very strange... try again with this update; if doens't work got to %APPDATA%\SMath\Debug\CurrencyUnits and post the log file Search
Offline mkraska
#7 Posted : 17 December 2013 15:41:16(UTC)
mkraska
The results were overly wide, thus i cut them.
Offline omorr
#8 Posted : 17 December 2013 15:41:47(UTC)
omorr
Serbia
Failed again
Here is the log file
File Attachment(s):
log.txt (2kb) downloaded 52 time(s).
#9 Posted : 17 December 2013 18:09:29(UTC)
seems a proxy/firewall authorization problem... I suppose that NetTest("http://www.google.com"Wink and NetTest("http://www.google.de"Wink will produce the same results Sad
Failed again
I've made another little modification, could you try again?
Offline omorr
#10 Posted : 17 December 2013 20:31:12(UTC)
omorr
Serbia
It seems that this plugin is not going to install into the Martins' unofficial build. I figured out by the second line of the log file.
I tried it on the official one and it seems to be Ok
File Attachment(s):
log.txt (12kb) downloaded 46 time(s).
on 17/12/2013(UTC)
#11 Posted : 17 December 2013 20:52:02(UTC)
thank you Radovan, now I understand Good
the plugin looks for the files in the %APPDATA% folder, I'll try to fix it Good
[EDIT] UPDATED: this version should work properly both in the official and the unofficial versions
Edited by user 17 December 2013 21:41:45(UTC)  | Reason: Not specified
on 17/12/2013(UTC)
Offline omorr
#12 Posted : 17 December 2013 22:08:09(UTC)
omorr
Serbia
Yes it works, thank you Good
Offline mkraska
#13 Posted : 18 December 2013 00:30:14(UTC)
mkraska
In our school LAN, the connectivity is broken, at home web access works (official and unofficial version). I shall include the plugin in the next release of the inofficial distribution.
on 18/12/2013(UTC)
#14 Posted : 18 December 2013 05:14:35(UTC)
UPDATED
- error handling: LOGs will be placed in the relative "extensions\debug\CurrencyUnits" folder (so the portable version has a portable debug path)
- For developers only: added a log tool to output a Term[] tree representation (see the CurrencyUnits Implementer.cs).
2013-12-18 17_05_51-C__Users_Davide_AppData_Roaming_SMath_extensions_debug_CurrencyUnits_log.txt - N.png
#15 Posted : 04 January 2014 03:36:49(UTC)
UPDATED
- checks for network availability before each ECB update attempt;
- LOG tools updated (session start is no longer registered)
- NetTest() removed.
Offline mkraska
#16 Posted : 05 September 2018 13:22:04(UTC)
mkraska
The yahoo download service for exchange rates has been discontinued. See their forum post.
Therefore, the function GetYahooExchangeRate() reports that the remote name could not be resolved.
I recommend to adjust the error message to "Service discontinued by Yahoo. Use function .... instead."
Perhaps some other source is available in replacement. However, I would not push this, because I rarely use it. Just cleaning up documentation.
Edit: filed as SS-3559
Edited by user 05 September 2018 13:33:24(UTC)  | Reason: Not specified
on 05/09/2018(UTC)
#17 Posted : 24 October 2018 01:59:34(UTC)
PLUGIN UPDATED SMath Studio 0.99.6839 and later
  • [SS-3560] restored unit as input argument in SetCurrencyUnits();
  • [SS-3559] since Yahoo service is discontinued now GetYahooExchangeRate() is hidden in the dynamic assistance and returns directly an error message if called;
#18 Posted : 27 March 2021 18:39:45(UTC)
PLUGIN UPDATED SMath Studio 0.99.7739 Nightly Build and later
  • added Currency units (symbols) toolbox;
NOTE:
  • symbols are sorted by unicode code;
  • symbols are subject to font implementation;
  • these are decorative symbols; you have to define yourself exchange rates on the worksheet to mix them;
Edited by user 27 March 2021 18:50:47(UTC)  | Reason: Not specified
Similar Topics
[FIXED] Currency Units plugin stopped working. Please fix it. (Bugs & Problems)
by Stargate38 15/03/2023 00:11:58(UTC)
