Joined: 04/07/2010(UTC) Posts: 178 Was thanked: 19 time(s) in 13 post(s)
I was resurrecting my WizFunctions for use with the newer version of SMath Studio and code that used to work now doesn't. The problem seems to be with Store.AddDefinition. Possible causes are Definition.IsFunction has no object reference but is ReadOnly so no way to set it. Or AddDefinition variables() needs to be initialized and I don't have a clue to what. Any suggestions would be appreciated. Thanks. [Moderator] Moved.Edited by moderator 18 August 2013 18:11:05(UTC)
Ed |
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1332 time(s) in 876 post(s)
Hi TheWizEd Here and here you can see some updated store.AddDefinition examples Best regards, Davide |
w3b5urf3r I looked at your examples and at least now it doesn't crash but it's not storing the variable. What am i doing wrong? Its in "zsival(vname,value)". My idea is to be able to set variables from a source other than SMath Studio, such as a file. Code: Public Function ExpressionEvaluation(root As SMath.Manager.Term, args()() As SMath.Manager.Term, ByRef context As SMath.Math.Store, ByRef result() As SMath.Manager.Term) As Boolean Implements SMath.Math.IPluginLowLevelEvaluation.ExpressionEvaluation
Dim bResult As Boolean
Dim sValue As String
Dim dTerms As Term()
Dim tTerms(0) As Term
Dim answer As New List(Of Term)
Dim i As Integer
Dim j As Integer
bResult = False
sValue = ""
If root.Type = TermType.Function And root.Text = "ztest" Then
For i = args.GetLowerBound(0) To args.GetUpperBound(0)
sValue = sValue + "i=" + Str(i) + ": "
For j = args(i).GetLowerBound(0) To args(i).GetUpperBound(0)
sValue = sValue + " j=" + Str(j) + ": <" + args(i)(j).ToString + ">"
Next
dTerms = Decision.Preprocessing(args(i), context)
sValue = sValue + vbCrLf + "i=" + Str(i) + ": "
sValue = sValue + ListTerms(dTerms)
Next
MsgBox(sValue)
answer.AddRange(Converter.ToTerms("1"))
result = answer.ToArray()
bResult = True
ElseIf root.Type = TermType.Function And root.Text = "zsival" Then
dTerms = Decision.Preprocessing(args(1), context)
MsgBox(ListTerms(dTerms))
context.AddDefinition(args(0)(0).ToString, dTerms, tTerms)
answer.AddRange(dTerms)
bResult = True
End If
Return bResult
End Function
Ed |
try using: instead of: |
w3b5urf3r
That worked. Thanks much. |
Ed |
You're welcome, I'm glad to see you back in action Best regards, Davide |
Not sure if it matters but I made some minor changes to my code so an instance of the empty Term array was created instead of using the local variable array. Replaced with Code:
Dim tTerms As Term()
tTerms = New Term() {}
Ed |
1 user thanked TheWizEd for this useful post.
