Offline TheWizEd
#1 Posted : 18 August 2013 17:41:53(UTC)
TheWizEd
Was thanked: 19 time(s) in 13 post(s)
I was resurrecting my WizFunctions for use with the newer version of SMath Studio and code that used to work now doesn't.
The problem seems to be with Store.AddDefinition. Possible causes are Definition.IsFunction has no object reference but is ReadOnly so no way to set it. Or AddDefinition variables() needs to be initialized and I don't have a clue to what.
Any suggestions would be appreciated. Thanks.
[Moderator] Moved.
Edited by moderator 18 August 2013 18:11:05(UTC)  | Reason: Not specified
Ed
#2 Posted : 18 August 2013 17:57:06(UTC)
Hi TheWizEd Good
Here and here you can see some updated store.AddDefinition examples Good
Best regards,
Davide
Offline TheWizEd
#3 Posted : 19 August 2013 01:02:32(UTC)
TheWizEd
w3b5urf3r
I looked at your examples and at least now it doesn't crash but it's not storing the variable. What am i doing wrong? Its in "zsival(vname,value)". My idea is to be able to set variables from a source other than SMath Studio, such as a file.
Code:
    Public Function ExpressionEvaluation(root As SMath.Manager.Term, args()() As SMath.Manager.Term, ByRef context As SMath.Math.Store, ByRef result() As SMath.Manager.Term) As Boolean Implements SMath.Math.IPluginLowLevelEvaluation.ExpressionEvaluation
        Dim bResult As Boolean
        Dim sValue As String
        Dim dTerms As Term()
        Dim tTerms(0) As Term
        Dim answer As New List(Of Term)
        Dim i As Integer
        Dim j As Integer
        bResult = False
        sValue = ""
        If root.Type = TermType.Function And root.Text = "ztest" Then
            For i = args.GetLowerBound(0) To args.GetUpperBound(0)
                sValue = sValue + "i=" + Str(i) + ": "
                For j = args(i).GetLowerBound(0) To args(i).GetUpperBound(0)
                    sValue = sValue + " j=" + Str(j) + ": <" + args(i)(j).ToString + ">"
                Next
                dTerms = Decision.Preprocessing(args(i), context)
                sValue = sValue + vbCrLf + "i=" + Str(i) + ": "
                sValue = sValue + ListTerms(dTerms)
            Next
            MsgBox(sValue)
            answer.AddRange(Converter.ToTerms("1"))
            result = answer.ToArray()
            bResult = True
        ElseIf root.Type = TermType.Function And root.Text = "zsival" Then
            dTerms = Decision.Preprocessing(args(1), context)
            MsgBox(ListTerms(dTerms))
            context.AddDefinition(args(0)(0).ToString, dTerms, tTerms)
            answer.AddRange(dTerms)
            bResult = True
        End If
        Return bResult
    End Function
Ed
#4 Posted : 19 August 2013 03:34:50(UTC)
Good try using:
Code:
Dim tTerms(-1) As Term
instead of:
Code:
on 19/08/2013(UTC)
Offline TheWizEd
#5 Posted : 19 August 2013 06:46:24(UTC)
TheWizEd
w3b5urf3r
That worked. Thanks much.
Ed
#6 Posted : 19 August 2013 11:37:50(UTC)
You're welcome, I'm glad to see you back in action Foto
Best regards,
Davide
Offline TheWizEd
#7 Posted : 20 August 2013 06:58:51(UTC)
TheWizEd
Not sure if it matters but I made some minor changes to my code so an instance of the empty Term array was created instead of using the local variable array.
Replaced
Code:
with
Code:
        Dim tTerms As Term()
        tTerms = New Term() {}
Ed
thanks 1 user thanked TheWizEd for this useful post.
on 20/08/2013(UTC)
Similar Topics
Problem with AddDefinition (Extensions)
by TheWizEd 18/08/2013 17:41:53(UTC)
