List of examples, uploaded to wiki
Moderators:
Administrators,
Advanced Member,
OchkovVF,
omorr,
uni,
List of tutorials, uploaded to wiki
Moderators:
Administrators,
Advanced Member,
OchkovVF,
omorr,
uni,
Integration Trapeze
Integration Trapeze
17/05/2023 19:58:03(UTC)
0
141
Simpson versus Trapezoidal method used for integration
The Trapezoidal method is compared with the Simpson method, both using Richardson extrapolation
Javier Ochoa
16/05/2023 16:51:42(UTC)
3
247
17/05/2023 13:56:59(UTC)
Bubble point of a mixture of components
Bubble Point calculation with several nonlinear solvers in SMath Studio
Javier Ochoa
16/05/2023 16:41:44(UTC)
2
170
Javier Ochoa
17/05/2023 01:18:44(UTC)
Equilibrium Flash calculations
Equilibrium Flash solved with different nonlinear solvers and SMath Studio
Javier Ochoa
16/05/2023 17:18:42(UTC)
0
144
Javier Ochoa
Thermodynamics calculations example
Estimate the vapor pressure of ethylbenzene at 460 K, using the Harlacher and Brown
Javier Ochoa
16/05/2023 16:59:12(UTC)
0
159
Javier Ochoa
Chemical Reaction order determination
Using a table you can determine the reaction order easily
Javier Ochoa
16/05/2023 02:08:14(UTC)
3
211
16/05/2023 16:34:07(UTC)
Mass flux and orifice meter calculations
This example use units within the equations to calculate the size of an orifice meter in a pipe
Javier Ochoa
16/05/2023 02:18:03(UTC)
3
225
16/05/2023 16:18:11(UTC)
Linear Regression forced through origin
Linear Regression Equations solved with two different approaches.
Javier Ochoa
16/05/2023 01:34:36(UTC)
3
320
Javier Ochoa
16/05/2023 16:00:05(UTC)
Evaluating the thermal dryer capabilities
This Worksheet solves the evaluation of a simple thermal dryer used in process engineering
Javier Ochoa
16/05/2023 02:25:05(UTC)
0
126
Javier Ochoa
Solve f(x,y) Techniques
16/04/2023 22:07:10(UTC)
1
279
15/05/2023 16:51:17(UTC)
Image Cross Hair
Image Cross Hair
15/05/2023 15:10:58(UTC)
0
142
Convex Hull
Convex Hull
15/05/2023 14:53:41(UTC)
0
121
Charmap Demo
Charmap Demo
08/05/2023 18:15:42(UTC)
0
175
Dispatch X Direction
08/05/2023 16:48:41(UTC)
0
149
FindIndex
FindIndex
07/05/2023 02:32:36(UTC)
0
187
07/05/2023 15:51:01(UTC)
Guest (2)
