Offline Javier Ochoa
#1 Posted : 16 May 2023 16:51:42(UTC)
Javier Ochoa
Rank: Member
Argentina
I was trying to understand how to use the numerical integration with the Simpson and Trapezoidal method. I could also explain the difference between the two methods, based on an example found in the forum.
I also applied the numerical integration to found the flow rate of a pump during the start up and shut down processes, which is useful to some degree for many engineers.
Hope it help,
Kind regards,
romberg_integration_exmple.sm (38kb) downloaded 21 time(s).
romberg_integration.sm (31kb) downloaded 19 time(s).
#2 Posted : 16 May 2023 21:59:09(UTC)
Was thanked: 961 time(s) in 789 post(s)
Trapeze suits better certain functions vs Simpson.
The converse is true: Simpson fits better certain function vs Trapeze.
Romberg/Simpson kernel is a much different story.
It converts the range of the variate of integration [0 ..1]
Last example: Trapeze better than Simpson ... poor vs ∫kernel.
Integral COMPANION Trapeze.sm (37kb) downloaded 15 time(s).
on 17/05/2023(UTC)
#3 Posted : 17 May 2023 01:21:42(UTC)
Javier Ochoa
Rank: Member
Argentina
Hi Jean,
I will take a look at your worksheet in orden to understand your advice.
I always wish to learn a bit more.
Thanks,
#4 Posted : 17 May 2023 13:56:59(UTC)
Originally Posted by: Javier Ochoa Go to Quoted Post
Hi Jean,
I will take a look at your worksheet in order to understand your advice.
Visit Samples about Trapeze Integration, will be attached today.
