Offline TheWizEd
#1 Posted : 04 May 2011 23:31:10(UTC)
TheWizEd
Was thanked: 19 time(s) in 13 post(s)
I've been using SMath (0.89) for about a year now and never experience this. Its why I alway put the result next to the equation to be sure I'm getting a reasonable result. The value of Wdsw is 10^31 when it should have been only 757. If I set optimization as Numeric I get the correct result. More reason to keep a check on running results. If I hadn't who knows what the final result would be. Confusion
Ed
Offline omorr
#2 Posted : 05 May 2011 13:58:51(UTC)
omorr
Serbia
Hello Ed,
This is one more example among others where the "Symbolic" optimization had problems with. I tried to reproduce it and the value of W.dsw is somewhat different than in your case.
Open in SMath Cloud
Here - "None" or "Numeric" will give the correct numerical value.
Someone on this Forum suggested having the option to set "None" or "Numeric" as default instead of "Symbolic". optimization. I suppose that this might be one of the possibility, until the fixing of this problem.
Offline eng01
#3 Posted : 18 May 2011 12:10:25(UTC)
eng01
atan(0.5) = 1.5359 according to SMath Studio... I beg to differ
angle units set to degrees
using version 0.89 (build 3856)
Offline omorr
#4 Posted : 18 May 2011 12:30:07(UTC)
omorr
Serbia
This was a known issue and corrected in 0.89.9. There is no "Angle units" option anymore
radians - no units or unit "rad"
degrees - units "deg" or "°"
Open in SMath Cloud
Strange?? Live version gives wrong result here. The 0.89.8 version gives the correct result
atan(0.5)=26.5651@'deg
EDIT: I messed up with "grad" and "deg", sorry Blush
Edited by user 18 May 2011 15:36:04(UTC)  | Reason: Not specified
Offline Peter
#5 Posted : 18 May 2011 15:04:48(UTC)
Peter
Rank: Member
Was thanked: 8 time(s) in 6 post(s)
Hello Radovan,
I think, SMath live calculates correct.
But the result unit is grad, not degree (400grad = 400gon = 360degree).
Best Regards,
Peter
Offline omorr
#6 Posted : 18 May 2011 15:33:12(UTC)
omorr
Serbia
Peter wrote:
...But the result unit is grad, not degree (400grad = 400gon = 360degree).
Thank you Peter, you are right.
Sorry, my mistake - I messed up "grad" and "deg" Blush
Offline Peter
#7 Posted : 19 May 2011 08:35:16(UTC)
Peter
Rank: Member
Hello Radovan,
in my opinion the unit 1grad = 1gon in SMath leads to mistakes, because grad is
normally used as alternative for deg.
To avoid confusion and mistakes I recommend to delete the unit grad from the unit-list in SMath or redefine it.
Btw., in MathCad: 1Grad = 1deg
Best Regards,
Peter
thanks 1 user thanked Peter for this useful post.
on 19/05/2011(UTC)
Similar Topics
Strange results of nested vectorize() for nested matrices (Bugs & Problems)
by mikekaganski 22/04/2016 12:40:34(UTC)
