Offline zureks
#1 Posted : 04 March 2011 14:39:06(UTC)
zureks
I have the following peculiar problem which seems to be linked to the "while loop". I calculate a value and iterate it a few times in a while loop (please see the link below). The result of the calculation changes very little between 3 or 4 iterations. However, when I try to use this result in an equation later I get an error message "Result is above max. allowed positive number."
This happens when the while loop is executed 4 times and more (bottom part of the screenshot), but does not when the loop is executed 3 times or less (top part). The numerical value changes less than 5%, so it cannot be that?
https://docs.google.com/..._GB&authkey=CObT0e8O
I would appreciate any comments.
Stan
Offline omorr
#2 Posted : 04 March 2011 15:57:45(UTC)
omorr
Serbia
Hello Stan,
In those or similar problems with the same error message, you can try disabling Symbolic optimization (Right click and choose Optimization|None or Numeric). On the other hand, when you have an iterative procedure as in your case, "gap=f(gap)", the symbolic answer might be quite complicated including the mentioned error message "Result is above max. allowed positive number.". Moreover, you are interested only in the numerical value and therefore you might consider using eval() function in those cases i.e. "gap=eval(f(gap)".
Offline zureks
#3 Posted : 05 March 2011 22:17:33(UTC)
zureks
Thank you Radovan.
I know I can find a workaround, but it was just interesting to see that even though there is no problem with calculating the number (the while loop always executes fine) the value does not work when used later.
Stan
