Offline sleschke
#1 Posted : 06 February 2009 16:24:44(UTC)
sleschke
Rank: Member
It seems that you can not change the size, color and background of existing text.
The settings only apply to new text that is typed in.
If I select existing text and change the settings nothing will happen.
Offline Andrey Ivashov
#2 Posted : 06 February 2009 17:12:36(UTC)
Thanks, this is actual only for Handheld version. Will be fixed ASAP.
Offline apluscw
#3 Posted : 09 March 2010 00:38:14(UTC)
apluscw
The same behavior is observable with the latest PC version. This is such a promising program, but not being able to change text is a pretty big weakness. I hope it is an easy fix. Good
I find SMath much easier to use than MathCad. While I really like MathCad, I hadn't used it for awhile and found it hard to get back into recently. With SMath, I was up and running in no time at all.
#4 Posted : 09 March 2010 01:19:28(UTC)
Can't reproduce it. After text area is created you need just select this text area (not the text inside) and then change preferred size and/or colors.
Thank you. Glad you enjoy it!
Best regards, Andrey Ivashov.
Offline apluscw
#5 Posted : 09 March 2010 03:12:26(UTC)
apluscw
OK. What threw me is I had expected to be able to highlight the text in text edit mode and change the highlighted text. Normally, in most Windows apps, you can do that. If I highlight the text like I am going to move it, I can change the settings of the entire block of text.
Some additional feedback:
1. If you could change the text when highlighted it would be easier on folks like me that are used to editing text that way, plus it would allow mixed formatting within a text box. (Perhaps that is technically difficult to do?)
2. Having access to the conventional underline, italics and bold font options would be very appealing. I went back to highlight my text the way I had intended to and found the lack of those options very limiting.
