Offline scooter
#1 Posted : 24 February 2011 01:13:57(UTC)
scooter
I want to use the complex units for electric power:
S:VA volt-amperes (apparent power)
Q:VAR volt-ampere-reactive (reactive power)
P:W real power (supported yet)
Z: Ohm Impedance
phi= angle of Z and S
S=P+Q·j (using j instead i for imaginary unit to not confues with i for intensity)
S=V·I*
Z=V/I
Z=R+X·j
Edited by user 24 February 2011 01:15:56(UTC)  | Reason: Not specified
Offline TheWizEd
#2 Posted : 24 February 2011 03:22:24(UTC)
TheWizEd
Was thanked: 19 time(s) in 13 post(s)
Don't know about the electrical units but it is customary for i to refer to the imaginary part of a complex number or sqrt(-1). In my opinion that one should not be changed. Personnally if a variable has the same symbol as a SMath unit I intentionally change the variable name to something else to avoid conflict with internal names. This is even though you can have a variable name with the same name as a unit without conflict. For example SMath will not confuse the variable name ft with the units 'ft (feet).
Ed
Offline scooter
#3 Posted : 24 February 2011 21:07:28(UTC)
scooter
I'm going to try defining the variable j with the value i.
For the rest of units is mor complex
Offline TheWizEd
#4 Posted : 26 February 2011 19:30:15(UTC)
TheWizEd
scooter,
Perhaps some of the units you propose would be good canidates for built-in units, you can create your own units. You can also create a substitue for imaginary i.
As I see it there are three different name formats. One is just the name by itself, the second is preceeded by a single quote and this is supposed to be used for units, the third is subscripted by typing dot. The third convention with out a subscript could be confusing though since you don't see the dot.
Ed
Similar Topics
request of more units (Feature Requests)
by baijo 08/04/2014 16:46:14(UTC)
