Just like to say what an excellent program Smath is. I've used Smath on windows 7 32 bit, window xp and windows mobile 6.1 without problem for over a year now, but unable to get Smath to run on new laptop with window 7 64 bit. Has anybody else experienced this problem? Does Smath work with windows 7 64 bit? Edited by user 10 February 2011 02:24:53(UTC)
| Reason: Not specified
Joined: 04/07/2010(UTC) Posts: 178 Was thanked: 19 time(s) in 13 post(s)
jlm,
I've been using SMath 0.89 on Windows 7 Pro 64 bit for a while now without any problems.
Good luck.
Ed |
Ed |
Thanks Ed, managed to solve the problem. For some reason widows 7 64 bit won't allow me to run the Smath across a network. If I run it locally from the C:\ drive, it works fine
Joined: 17/01/2011(UTC) Posts: 4 Location: Ottawa Ontario Canada
