Offline TheWizEd
#1 Posted : 09 January 2011 18:30:22(UTC)
TheWizEd
Was thanked: 19 time(s) in 13 post(s)
I'm having a problem with summation.
I am comparing the area calculation with a known solution. First I use sum. The result is incorrect.
So I check it using a different method. Result is correct.
Check against an Excel solution. Result is correct.
Am I misinterpreting the sum function? Sad
http://smath.info/wiki/G...eWizEd%2fsectionprop.zip
Edited by user 09 January 2011 18:35:03(UTC)  | Reason: Not specified
Ed
Offline omorr
#2 Posted : 10 January 2011 12:35:51(UTC)
omorr
Serbia
Hello Ed,
I think there is a bug in the summation operator.
Open in SMath Cloud
These two results should be the same, but they are not. I can not figure out how the summation operator get that number?
Here is another example - I am also puzzled here???
t←mat(2,5,1,2,2,2)
el(t,1,1)*el(t,2,2)-el(t,2,1)*el(t,1,2)=-1
sum((el(t,1,1)*el(t,2,2)-el(t,2,1)*el(t,1,2)),n,1,1)=3
Edited by user 10 January 2011 12:56:18(UTC)  | Reason: Not specified
on 10/01/2011(UTC)
Offline TheWizEd
#3 Posted : 10 January 2011 22:04:59(UTC)
TheWizEd
Radovan,
Thanks for the help.
I can get around it by a user function for now.
Ed
Ed
Similar Topics
Problem with summation 2 (Bugs & Problems)
by Guest 11/01/2011 04:47:49(UTC)
