Offline RFreund
#1 Posted : 13 March 2017 00:10:51(UTC)
RFreund
Was thanked: 19 time(s) in 17 post(s)
Is it possible to create a combobox that has a variable matrix. Meaning if x use Y matrix, else use Z matrix.
See attached. I have 2 matrices. Depending on what is selected from a different combobox I'd like to change the matrix that the next combobox uses.
I understand that I can put the "if statement" between the comboboxes but this doesn't look as clean Good
Thanks in advance!
Combobox List - variable matrix.sm (11kb) downloaded 95 time(s).
Edit_1:
Note - If actually using this for Masonry the if statement is incorrect. This doesn't matter for the question at hand though
Edited by user 13 March 2017 00:14:01(UTC)  | Reason: See Edit_1
#2 Posted : 13 March 2017 01:52:44(UTC)
But actually you have the if statement, right before the first combobox; how it is more clean? Good
If you use a line() on MMCS, then you can place MMCS:MMCS out of the right margin after the first combobox making it available for the 2nd combobox. If you need to reuse it, you can define MMCS as a function MMCS(MUM), and then you can define MMCS:MMCS(MUM) after the first combobox (below or out of the printing bounds)
