The Smath 'Genfit' is ½ robust compared to Mathcad. Up until now, that's the only offer from the bakery. This document shows the automatic iterative procedure. The art under the hood is the initials. As a rule, there is no rule about guessing the "initials". A rule that works generally is trial/error to pass the manual initials through two points of the data set. You can recomfort yourself that some model are so reactive that even Mathcad can not do. Jean Genfit Iterate.sm (43kb) downloaded 35 time(s).
