SMath Studio Forum
Bugs & Problems
[Nonlinear solver] Vectorize Operator and Symbolic Optimization in SS 6179
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 127 time(s) in 82 post(s)
The attached image shows different results in symbolic optimization in using Vetorize Operator, and consequently generates an error when using "FindRoot" function in the attached worksheet. When Equations 1B & 2B are disabled and 1A & 2A enabled, "FindRoot" gives the result. Vectorize error - Symbolic Optimization.sm (190kb) downloaded 25 time(s).Edited by moderator 03 February 2017 13:34:26(UTC)
if you initialize the vector Q, then it works
Q:mat(el(Q,1),el(Q,2),el(Q,3),el(Q,4),4,1)
2 users thanked PompelmoTell for this useful post.
on 03/02/2017(UTC), on 03/02/2017(UTC)
Your red vectorise is just a display, i.e: not an assignment. Unlike the "red vectorise", the "blue vectorise" ASSIGNS the vector required by FindRoots, thus immaterial wrt Symbolic/Numeric/NONE
The suggestion to initialise is not technical to me [just a comment]. It simply confuses matters. There is a long route to explore/clarify the Smath Vectorise operator
SMath Studio Forum
Bugs & Problems
