Joined: 23/03/2016(UTC) Posts: 278 Was thanked: 91 time(s) in 57 post(s)
Has anyone successfully tried implementing their own dedicated SMath Server? I imagine that being something like a personal "Smath in the Cloud" only where you can control the version and include any plugins and snippets you'd like. I know services like the AWS Appstream 2.0 could accomplish this, but that seems a bit overkill for my uses.
Personally I have devices with just about every OS. At work I use mostly Win7. At home I have OSX, ChromeOS, a couple spare linux boxes, and an old Windows box that I rarely use. I rely on Maxima or Maple plugins to perform some of the symbolic arithmetic when I'm at work, but I can't get these to work without VMs on non windows PCs. I was thinking it would be nice to setup a server and access my own copy of SMath that is the same no matter what device I'm using.
I could just setup an old Windows box and remote desktop and run SMath, but I'd like to implement some way open files locally on my PC if necessary.
Any thoughts? |
No useful suggestions, but I like the idea. Having snippets available on each device would be great.
Actually having snippets available on multiple devices is not hard to do. I presently do this by using the portable version housed on a server. I can map that server to a location on my PC. Personally, I use Box and Box Sync to do this. The problem with that approach is with non Windows PCs. I could run the portable version through VM or mono on a non-Windows PC, but the plugins don't always work. Edited by user 02 February 2017 18:05:27(UTC)
± you are asking for a "virtual something" to execute about any OS [Win, Mac ...] You may try "Google Maths" for freeware applications. For sure, you won't be able to run Mathcad, Maple, Matlab ... etc.
