SMath Studio Forum
Samples
Basic single variable Secant (Newton-Raphson) Solver that just works
I figured I am not the only one who can benefit from a simple numeric solver that "just works". It will likely become obsolete once Davide updates the Nonlinear Solvers plugin. Enjoy. SolveNewtonRaphson.sm (13kb) downloaded 30 time(s).Edited by user 23 November 2016 22:10:30(UTC)
| Reason: Not specified
Interesting, but good thing Smath 5346 does it as well w/o all that complexity. Shouldn't it be constructed around "While" loop ? Remember that any invented iterative solver for Smath can't exceed better accuracy than around 12 decimals because of the granularty of Smath. The native Smath 'solve' has a universal structure wrt: 1. is implicit 2. the bracketing [x1,x2] 3. very easy to handle. Jean
Alex, The Newton-Raphson code in your first post would surely work here in two cumbersome presentations. For this example, 'roots' is a better candidate.
If only either of the two could handle the units I would not need to go through all the trouble. They do not, hence I had to get inventive.
SMath Studio Forum
Samples
