Smath does not support reverse cols order in "submatrix". Alternately, here is the module. Read more in the attached. Jean Utilities Matrix Mirror Exercise.sm (20kb) downloaded 20 time(s).
You even don't have to wait for the vector indices, at least for the mirror. See hereThe mirror implementation is straightforward to understand (transpose, reverse, transpose) The diagonal is a nasty indexing trick, which is that far from paper and pencil notation that it can't be recommended unless you want to obfuscate your algorithm (then best use excel). You just square the row/column index range elements to access the diagonal elements in linear indexing. This, however, uses the vector index feature. Edited by user 09 September 2016 18:35:03(UTC)
Joined: 17/01/2013(UTC) Posts: 296 Location: Khabarovsk, Russia Was thanked: 151 time(s) in 107 post(s)
Originally Posted by: mkraska The diagonal is a nasty indexing trick, which is that far from paper and pencil notation that it can't be recommended unless you want to obfuscate your algorithm (then best use excel). You just square the row/column index range elements to access the diagonal elements in linear indexing. This, however, uses the vector index feature. diagonal(M):el(M,(range(0,(rows(M)-1)))*(rows(M)+1)+1) Edited by user 11 September 2016 11:13:28(UTC)
Best regards, Mike Kaganski |
1 user thanked mikekaganski for this useful post.
