SMath Studio Forum
Samples
Interpolation of closed curves
Today I've found interesting article here: https://habrahabr.ru/post/309210/. After reading decided to make the same algorithm inside SMath Studio. Successfully. ClosedCurveSpline.sm (46kb) downloaded 52 time(s).Many thanks to the author of the initial article, Denxc! Best regards, Andrey Ivashov.
on 06/09/2016(UTC), on 06/09/2016(UTC), on 06/09/2016(UTC), on 06/09/2016(UTC), on 06/09/2016(UTC)
Thanks Andrey for the work sheet [though it crashes 5346]. The coding is too big for my small head. Similarly to your coding, here is attached the Mathcad "Esplina" [*.bmp]. De Boor is more a graphical closed contour based on its convex hull properties. I was two months old in Smath the attached de Boor was created. Maybe there is room to compute faster. Jean Spline De Boor [Esplina].sm (52kb) downloaded 36 time(s).
SMath Studio Forum
Samples
