  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,494   Was thanked: 1766 time(s) in 597 post(s)
SMath Studio 0.98.5983 available - SS-2346: Handling of text strings to paste into the worksheet improved;
- Changing size of matrix inside the element of output matrix disabled in order to fix critical error happened in such cases;
- Added ability to select answer of math expression with manually set unit;
- SS-2318: Corrections made, see Preprocessing of symbolic data / functions' arguments for details;
- Cloud: Scrolling to top on every key down issue fixed.
Download
 6 users thanked Andrey Ivashov for this useful post.
on 20/05/2016(UTC), on 20/05/2016(UTC), on 20/05/2016(UTC), on 20/05/2016(UTC), on 21/05/2016(UTC), on 22/05/2016(UTC)
Was thanked: 9 time(s) in 8 post(s)
The attached sample doesn't work with the latest build 5983, but worked fine with all previous versions. It indicates error x - not defined. Actually x is dummy, it was used as a place-holder for symbolic calculation. Best regards cic3.sm (5kb) downloaded 60 time(s).
