SMath Studio Forum
Questions
How to Hard Define a Variable with Combobox
I like to use the ComboBoxList however there are issues with include() when assigning values from the comboboxlist. Is there a way to me "hard define" a variable after using the comboboxlist so that it is as if I 'manually' input the variable?
Thanks!!
Interesting, but "Insert Combo box" crashes Smath 5346 ! ?
Originally Posted by: RFreund I like to use the ComboBoxList however there are issues with include() when assigning values from the comboboxlist. Is there a way to me "hard define" a variable after using the comboboxlist so that it is as if I 'manually' input the variable?
Thanks!! As for now there aren't workarounds from user-side. Probably a dirty solution (DEV-side) would be to provide an access to the output values in the xml with an "hook tag" for include. However the content wouldn't be "dynamical". Originally Posted by: Jean Giraud Interesting, but "Insert Combo box" crashes Smath 5346 ! ?
Jean Merci beaucoup Jean, bug confirmed, source of the pain found. I'll update the plugin ASAP. Edited by user 13 February 2016 17:28:01(UTC)
I see, I'll keep watch for any updates.
Thanks!
SMath Studio Forum
Questions
