7 Pages«<567
Offline Razonar
#121 Posted : 10 December 2021 18:35:23(UTC)
Razonar
Uruguay
Was thanked: 506 time(s) in 325 post(s)
Hi Viacheslav. Thanks again. I guess that with this new feature SMath must to be very close of version 1.0.
Just a question about derivatives. Yours ode solvers returns n-1 columns for the n-degree differential equation, so: which is the better way to implement y <n> (x) : diff(y(x),x,n) ? Because SMath diff doesn't recognize lspline.
I think in 3 or 4 ways: return n columns for the differential equation of degree n, return functions y'(x), y''(x), ... and y<n>(x) as you do for y(x), a function like lspline(3) but for the derivative (something like dlspline) since cubic splines have information about the derivative or a diff function like matlab's, which simply calculates the difference in the values of a vector, for each column of a matrix.
But the truth is, I don't know which method could be the best, nor do I have any idea what is the best way to obtain the function derived from the result of any of your many solvers at this time.
And one last question: could it be possible to implement the graph of parametric functions in the XY Plot plugin? Something like ParamtricPlot (x (t), y (t), a, b ) and that takes the number of points from the plugin configuration, or ParamtricPlot (x (t), y (t), a, b, N ) for N subdivisions (N + 1 points) of the interval a < t < b.
Offline uni
#122 Posted : 10 December 2021 20:42:11(UTC)
uni
Was thanked: 1117 time(s) in 644 post(s)
Originally Posted by: Razonar Go to Quoted Post
And one last question: could it be possible to implement the graph of parametric functions in the XY Plot plugin? Something like ParamtricPlot (x (t), y (t), a, b ) and that takes the number of points from the plugin configuration, or ParamtricPlot (x (t), y (t), a, b, N ) for N subdivisions (N 1 points) of the interval a
I think it is possible to mark a "vector" variable with a tilde "~": ~t. It might look like this. I need to think about whether this will work.
Russia ☭ forever
Viacheslav N. Mezentsev
on 11/12/2021(UTC)
Offline Razonar
#123 Posted : 11 December 2021 10:14:06(UTC)
Razonar
Uruguay
It looks pretty good.
In the attached an example about how to add an "extra" column to the ode solver for return the last derivative. In the "traditional" implementation it it is not necessary because it is simply the last component of D (t, Y), the argument function of the solvers for systems of differential equations. But if what you have is the higher-order differential equation, things are no longer so simple.
It also shows how to "sterilize units", an expression that I had never read or heard, but that I am copying from Pompelmo. I think it is an easy and effective way to be able to program functions like nonlinear or ode solvers that accept units.
RK23.sm (72kb) downloaded 20 time(s).
RK23.pdf (341kb) downloaded 17 time(s).
Edited by user 11 December 2021 10:16:00(UTC)  | Reason: Not specified
on 11/12/2021(UTC),  on 11/12/2021(UTC)
Offline uni
#124 Posted : 13 December 2021 13:52:46(UTC)
uni
SMath Studio compatibility
Plugin updated.
Changes:
- added support for ODE systems with many variables;
- Adams() ode solver added (explicit Adams-Bashforth 5);
- CWD and TOL variables added;
- project restructured.
I don't know what AB method is used in Mathcad, but it clearly uses an adaptive step, since the usual explicit AB method is unstable (the small stiffness of the task makes it so).
Click to enlarge Click to enlarge Click to enlarge
Mathcad%20Block.%20Adams.sm Lorenz%20attractor.sm Chua's%20circuit.sm
Edited by user 13 December 2021 18:22:33(UTC)  | Reason: Not specified
Russia ☭ forever
on 13/12/2021(UTC),  on 14/12/2021(UTC)
Offline uni
#125 Posted : 13 December 2021 21:48:49(UTC)
uni
Plugin updated.
Changes:
- Adams variable added (allows you to choose a method for the Adams() solver): "AB1".."AB8", "AB5" - default;
- CWD variable value changed.
To calculate the first steps of the method, Runge-Kutta of the 4th order is used, so while the order is not higher than the 5th it makes sense.
Click to enlarge
Edited by user 15 December 2021 15:50:36(UTC)  | Reason: Not specified
Russia ☭ forever
on 14/12/2021(UTC)
Offline uni
#126 Posted : 15 December 2021 15:49:35(UTC)
uni
SMath Studio compatibility rkfixed.cs
Plugin updated.
Changes:
- rkfixed variable added (allows you to choose a method for the rkfixed() solver: "RK1".."RK6", "RK4" - default);
- to calculate the first steps for the Adams() solver now Runge-Kutta of the 6th order is used.
Edited by user 16 December 2021 11:16:47(UTC)  | Reason: Not specified
Russia ☭ forever
on 15/12/2021(UTC)
Offline AleksMoisei
#127 Posted : 17 December 2021 18:39:58(UTC)
AleksMoisei
Скажите пожалуйста, можно ли с помощью данного расширения производить символьные расчеты как в Маткаде или только это касается графиков. Пробую посчитать символьно передаточную функцию, задействовал Maple Tools, simplify выдал что-то не то что должен был по моим разумениям. Raschjot17.sm (25kb) downloaded 8 time(s).
Edited by user 17 December 2021 18:41:52(UTC)  | Reason: Not specified
Offline uni
#128 Posted : 17 December 2021 19:30:28(UTC)
uni
Originally Posted by: AleksMoisei Go to Quoted Post
Скажите пожалуйста, можно ли с помощью данного расширения производить символьные расчеты как в Маткаде или только это касается графиков. Пробую посчитать символьно передаточную функцию, задействовал Maple Tools, simplify выдал что-то не то что должен был по моим разумениям.]
Это расширение большей частью реализует численные аналоги некоторых функций из Mathcad. Символьные же вычисления можно попробовать выполнять при помощи MapleTools и функции maple(). Если она работает как-то не так, то можно посмотреть о "переговорах" между движками при помощи файла лога MapleTools.log, который находится в папке с плагином, если в файле конфигурации MapleTools.config включена опция отладки (<Debug>True</Debug>).
Путь такой: %appdata%\SMath\extensions\plugins\32dfd679-8cfd-483a-b79a-19d5ea838750\
Его нужно скопировать и вставить в адресную строку Проводника. Дальше выбрать подпапку с последний версией плагина, отредактировать файл MapleTools.config при закрытой программе и запустить её снова. После этого при старте будет создаваться файл лога MapleTools.log, в котором можно увидеть что именно передаёт функция maple() в символьный движок дополнения и как тот отвечает. Ну, а дальше уже искать ошибки.
Следует также отметить, что синтаксис команды скорее всего будет отличаться, т.к. Mathcad имеет специальную обёртку, "скрывающую" некоторые дополнительные действия, чтобы перевести его запрос на понятный символьному движку "диалект". Поэтому нельзя в общем случае писать также как в Mathcad. Нужно понимать как работает Maple и быть знакомым с его командами, их форматами вызова.
Edited by user 17 December 2021 19:39:14(UTC)  | Reason: Not specified
Russia ☭ forever
Offline Razonar
#129 Posted : 17 December 2021 22:45:31(UTC)
Razonar
Uruguay
... Maple Tools, simplify выдал что-то не то что должен был по моим разумениям. Raschjot17.sm (25kb) downloaded 8 time(s).
Hi. Notice that SMath does not operate automatically expands matrix operations. Also, the maple's linalg package have some issues too, and sometimes needs to call evalm function, which means "eval as matrix".
If D is a scalar I suppose that the correct result is (2), but if it is a 2x2 matrix I think it is (3).
In both cases you cannot calculate A ^ (- 1) because the second column of A is zero.
Could you comment what is the expression you expect for A? Also perhaps something from this post may be useful to you: https://en.smath.com/for...d-laplace-transform.aspx
Offline uni
#130 Posted : 21 December 2021 12:26:33(UTC)
uni
Updated test for the ODE solvers.
Section Math ODE precision (uni).sm (35kb) downloaded 4 time(s).
Original document: Section Math ODE precision.sm (24kb) downloaded 46 time(s).
Edited by user 22 December 2021 22:38:38(UTC)  | Reason: Not specified
Russia ☭ forever
on 21/12/2021(UTC),  on 22/12/2021(UTC)
Offline uni
#131 Posted : 27 December 2021 23:04:34(UTC)
uni
I finally figured out how it works Good
Mathcad Block. Spring pendulum.sm (49kb) downloaded 14 time(s).
Edited by user 28 December 2021 01:19:04(UTC)  | Reason: Not specified
Russia ☭ forever
on 27/12/2021(UTC),  on 28/12/2021(UTC)
7 Pages«<567
