  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,300   Was thanked: 1132 time(s) in 653 post(s)
Mathcad Toolbox  Contents:
CurrentDirectory(1) - Gets or sets the fully qualified path of the current working directory. DocumentDirectory(1) - Gets the fully qualified path of the current document. GetFolderPath(1) - Gets the path to the system special folder identified by the specified enumeration. GETWAVINFO(1) - Creates a vector with four elements containing information about file. interp(4) - (vs,vx,vy,x) returns an interpolated value at x from the coefficients in vector vs, and the original data in vx and vy. Play(1) - Play sound file. pspline(2) - (vx,vy) returns a vector of second derivatives to build a cubic spline parabolic at the endpoints. pspline(3) - (vx,vy,x) returns a vector of second derivatives to build a cubic spline parabolic at the endpoints. lspline(2) - (vx,vy) returns a vector of second derivatives to build a cubic spline linear at the endpoints. lspline(3) - (vx,vy,x) returns a vector of second derivatives to build a cubic spline linear at the endpoints. READBIN(6) - ( file, type, endian, cols, skip, maxrows ) returns an array containing the binary data in file. READBMP(1) - Creates an array containing a grayscale representation of a bitmap format image file. READRGB(1) - Creates an array containing a red-green-blue packed matrix representation of the image file. READWAV(1) - Creates a matrix containing signal amplitudes in file. READ_BLUE(1) - Returns a matrix representing the RGB blue component of the image in file. READ_GREEN(1) - Returns a matrix representing the RGB green component of the image in file. READ_IMAGE(1) - Creates an array containing a grayscale representation of the image file. READ_RED(1) - Returns a matrix representing the RGB red component of the image in file. rfile(2) - ( path, filename ) Reads an expression from the file. Rkadapt(3) - (ode,y(x),xmax) uses the Runge-Kutta-Fehlberg method (RKF45). Rkadapt(4) - (ode,y(x),xmax,steps) uses the Runge-Kutta-Fehlberg method (RKF45). Rkadapt(5) - (ics,xmin,xmax,steps,D(x,y)) uses the Runge-Kutta-Fehlberg method (RKF45). rkfixed(3) - (ode,y(x),xmax) uses the fourth-order Runge-Kutta fixed-step method. rkfixed(4) - (ode,y(x),xmax,steps) uses the fourth-order Runge-Kutta fixed-step method. rkfixed(5) - (ics,xmin,xmax,steps,D(x,y)) uses the fourth-order Runge-Kutta fixed-step method. wfile(3) - ( value, path, filename ) Writes the expression to the file. WRITEBIN(4) - ( file, type, endian, M ) writes an array of scalars to the binary data file named file. WRITEWAV(4) - ( file, s, b, M ) Creates a WAV signal file out of a matrix.
Examples:  See also:● Intel ODE Solver Library● DotNumerics● SADEL● Matlab C++ Math Library● OSLO● lsoda● GNU Scientific Library (GSL)Edited by user 13 December 2021 18:31:39(UTC)
