Hello Andrey, I think this should be a bug. f(x)←5+f(x)f(1)=#This will not stop executing until it is interrupted. I think this is an infinite loop problem. Regards, Radovan Edited by moderator 30 September 2010 01:11:31(UTC)
Hello.
Thank you. Will check this later.
Regards.
Joined: 30/08/2009(UTC) Posts: 52 Location: Australia
what behaviour would you expect?
you are asking for 5+5+5....
Greg Locock wrote:what behaviour would you expect?
you are asking for 5+5+5.... Yes, Greg, that is the problem. We can have something like this: f(x)←xf(x)←f(x)/2f(5)=2.5But with this, we get in trouble. f(x)←f(x)/2f(5)=#@#The question is - Does it to be the user's problem to interrupt such a calculation or to suppress it by an error message? I was not sure about it, and that was my doubt about "endless loop". Regards, Radovan |
Fixed.
Hello Andrey, Sorry for being persistent, but I think I was not precise enough. The previous calculation will work in SMath - there was not a problem. But, try this: The problem is that this will never stop, until we "Interrupt processing". My question was - Should it be left this way or should it be stopped by SMath. Regards, Radovan |
This is also fixed. Now SMath Studio understands that it is not good practice to repeat substitution of the already substituted functions with the same names So one will not see infinite loops in such cases anymore. Regards.
