omorr wrote:Hello Andrey,
The F8 functionality is quite good. Changing the same names in the math regions at once. However, I've noticed that clicking on an emty space in the worksheet and pressin F8 can cause "Unhandled exception ... " error. It migh be due to my computer, of course - but it happened to me avery time.
I have the same problem, my os is winxp sp3( italian version) and use portable version 0.89 of Smath Studio
the details of error are:
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at System.ThrowHelper.ThrowArgumentOutOfRangeException()
at System.Collections.Generic.List`1.get_Item(Int32 index)
at SMath.Control.CanvasControl.ParseInsertString(String value)
at SMath.Control.CanvasControl.Insert(String value)
at SMath.Desktop.canv.ActionEscaper(String value)
at SMath.Desktop.canv.canvasControl1_PreviewKeyDown(Object sender, PreviewKeyDownEventArgs e)
at System.Windows.Forms.Control.OnPreviewKeyDown(PreviewKeyDownEventArgs e)
at System.Windows.Forms.Control.PreProcessControlMessageInternal(Control target, Message& msg)
at System.Windows.Forms.Application.ThreadContext.PreTranslateMessage(MSG& msg)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SMathStudio_Desktop
Assembly Version: 0.89.3856.7126
Win32 Version: 1.1.15.0
CodeBase: file:///C:/Programmi/smathstudio/SMathStudio_Desktop.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
ioman
Assembly Version: 0.89.3856.7122
Win32 Version: 0.89.3856.7122
CodeBase: file:///C:/Programmi/smathstudio/ioman.DLL
Accessibility
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
HTMLFileType
Assembly Version: 1.2.3856.6720
Win32 Version: 1.2.3856.6720
CodeBase: file:///C:/Programmi/smathstudio/plugins/HTMLFileType.dll
canvas
Assembly Version: 0.89.3856.7124
Win32 Version: 0.89.3856.7124
CodeBase: file:///C:/Programmi/smathstudio/canvas.DLL
SpecialFunctions
Assembly Version: 1.2.3856.6823
Win32 Version: 1.2.3856.6823
CodeBase: file:///C:/Programmi/smathstudio/plugins/SpecialFunctions.dll
XMCDFileType
Assembly Version: 1.2.3856.6795
Win32 Version: 1.2.3856.6795
CodeBase: file:///C:/Programmi/smathstudio/plugins/XMCDFileType.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
NuLib
Assembly Version: 1.55.3856.7123
Win32 Version: 1.55.3856.7123
CodeBase: file:///C:/Programmi/smathstudio/NuLib.DLL
SyLib
Assembly Version: 1.22.3856.7123
Win32 Version: 1.22.3856.7123
CodeBase: file:///C:/Programmi/smathstudio/SyLib.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Stefano
